33's or 35's
So. I want 35's but I don't know if they will fit. I have a 07 x with either 2 or 2.5 inches of lift. I have been thinking 33x12.50x17 Cooper discoverer stt. But if I can squeez em, I'd love to rock 35x12.50x17 Toyo mt. Any thoughts?
Thanks!
Thanks!
I have a 2.5 BB lift and trying to decide if I want 35's or a 295/70 17 Cooper STT. They both will fit mine with wheel spacers just not sure which one will fit the lift better. From what I have read 2.5 is tight for 35's but works...anything shorter should go 33's... you can go with flat fenders and the 35's with a 2" lift.
if you're even thinking about going 35's, i would just do it - i guarantee you that you will regret it if you don't. if needed, you can always install a 1" body lift to help make up the difference in clearance.
yes, the tires will cost a bit more, the extra body lift is cheap and can be had for about $150 and regearing may be desireable but not necessary. just listen to yourself, "i really want 35's" - i can assure you that this will turn into, "i should have gotten 35's" if you don't get them.
And I have always wanted Toyo mt's ever since I started driving. There beast! I will go to my local tire shop and ask them what they could so for me lift wise and cost. I will need to put on a steering stabilizer too then probably so I don't get epic death wobbles
Originally Posted by Yamaha90
If you're not worried about fuel economy, go with 35's.
They fit the wheel wells nicely
https://www.jk-forum.com/forums/show...es-and-Wobbles
Oh...and go 35's.
