35"s, no lift, but with flat flares?
Old May 20, 2008 | 01:40 PM
  #21
ksk's Avatar
ksk
Do yourself a favour and get a lift....cost is marginal compared to buying tyres...
KSK
Old May 20, 2008 | 05:44 PM
  #22
Chanceit's Avatar
Originally Posted by racer83l
I got the spacers on, ill post more pics once its not raining....
And I bought them from quadratec.com. They had them in stock.
They had different sets for 4 door and 2 door models.
Thank you.
Old May 22, 2008 | 05:30 AM
  #23
racer83l's Avatar
i got lazy, but here are the pics with the spacers installed
I still think I need some bigger tires now, but im going to hold off...
Old May 22, 2008 | 05:32 AM
  #24
SASQUATCH's Avatar
Narrow flares would have looked better IMO, even with the spacers it has the stock wagon train look, yet a few people like to have the protection, not sure where you stand with it. Cool though that it looks lifted with these flares
Old May 22, 2008 | 05:33 AM
  #25
SASQUATCH's Avatar
so I just installed a set of xenon hi clearance flares tonight.. Makes my stockers look tiny. I was thinking if a 2.5" BB and some 34-35s. But it looks like with these flares and proper backspacing I can clear a set of 35s without a lift at all. What do you all think? Will it rub? I would be using 35x12.5's. No idea on backspacing but I would prefer to use the MOABs I already have with some spidertrax spacers.
Thanks.
It will absolutely rub when flexing, spacers with the stock moabs will be required for no-rub turning. Just do a TF 2.5 budget boost if not a real lift.
Old May 22, 2008 | 05:51 AM
  #26
racer83l's Avatar
I really like the narrow flares, but on my old YJ I had some 12.5" MT's on stock flares and I must have gotten >3 tickets for having insufficient wheels flares. Didn't want the same problem with this Jeep.. too bad too because Im sure the narrow flares would look better.
Now im just gonna save a few more nickels and buy some tires/wheels, I pretty much decided on some 295 75 r16 nitto terra grapplers (33.3" diameter) on some soft 8's, cheap, should work well as a daily driver, all while using less gas and making my JK a little better in the dirt. AND Im not lifting, or at least dont plan on it anyway, As much as I would love to I dont get to wheel it enough to justify the modification..
Old May 22, 2008 | 06:07 AM
  #27
SASQUATCH's Avatar
Well that is the key, if you don't wheel that much then it becomes a financial waste to throw money into these Jeeps, it'll look good. Some states I guess have laws where tires can't stick out past. We must be lucky here in TX because it's absolutely ridiculous how a lot of them stick out....
Old May 22, 2008 | 01:41 PM
  #28
Ryno's Avatar
Cool license plate!
Old Jun 2, 2008 | 02:24 AM
  #29
paranoid's Avatar
Originally Posted by Ryno
If you go with a 1" body lift (as opposed to a suspension lift), your driveline angles and whatnot will be unchanged and the factory ride will be maintained. All a body lift does is raise the body up off the frame using 10 or 12 spacers. Raising the wheel wells up 1" theoretically gives enough room for a 2" taller tire since only half of the diameter sits above the axles. A 1" body lift and flat fenders should be able to clear 35s at full stuff without any problems. Plus it will keep the center of gravity low and will look awesome.
So has anyone done this, or seen it done. I am thinking seriously about doing this.
Old Jun 4, 2008 | 01:12 PM
  #30
jkx0778's Avatar
bump....
anymore pics of 35's with no lift but flat fenders?
anyone.... anyone.... Beuler .... Beuler....
