37" MTR kevlars?
Ok I'm thinking about buying 37" MTR K's because my 35" km2's are just to small but I like that they are a light tire. Ive heard good reviews on the MTR's for the most part and they seem pretty light for a 37" tire at 76 lbs or so.
They are going on my daily driver JKU with
3.5" RK X factor lift
4:88 gears. I wheel it about once or twice a month.
My question is I've heard people having balancing issues with these tires? Saying they take tons of weights to get balanced? I'm already having balancing issues with my km2's so I don't want to run into that problem again.
Any opinions on these tires are welcome and how are they on the highway?
Same exact situation here. I am getting my 37 mtr/k put on today. I've heard the same things that you said. I read somewhere that things have gotten better with them.
I am going with them because true size and they are light like you said. For the most part they have excellent reviews and are cheaper.
Ok I'm thinking about buying 37" MTR K's because my 35" km2's are just to small but I like that they are a light tire. Ive heard good reviews on the MTR's for the most part and they seem pretty light for a 37" tire at 76 lbs or so. They are going on my daily driver JKU with 3.5" RK X factor lift 4:88 gears. I wheel it about once or twice a month. My question is I've heard people having balancing issues with these tires? Saying they take tons of weights to get balanced? I'm already having balancing issues with my km2's so I don't want to run into that problem again. Any opinions on these tires are welcome and how are they on the highway?
I've had mine for a couple months. Zero issues balancing. Here is how much weight was used for each of my wheels (most to least): 6oz, 3oz, 3oz, .25oz. Very little. No issues driving, roll nice and straight.
What I will note, but don't have any actual data on this: I ordered 5 tires, 4 came from one place, and 1 from another. The 4 that came together were manufactured in 2013, the other was 2012. I mounted them to ATX Slab beadlocks. The 2013 tires were slightly different and mounted with ease. The 2012 tire was a total beast to install. The lock ring also sits further out than all the other tires. Hard to say what exactly was different, but it appeared the mold had been changed/improved (at least the bead). I haven't had the spare balanced yet as it came a few days later and I haven't stopped to have it done yet.
Other than that, they are much louder and ride rougher than my Duratracs did, but I assumed that would be the case.
It seems to be hit or miss with these tires. My 35's would not balance so I sold them. I've heard better things with newer 37s, which I was thinking of trying, but I just can't after my experience with the 35's, plus they aren't very good in snow.
My 35" MTRs were easy to balance. Took them to sears to mount and balance. I told them I heard they were tough - the kid that did it said he had no issues and was done in less than an hour.
I have put 12k miles on them, all of which have been trouble free and I've never had to rebalance them since day 1.
I had issues balancing my 37's until I found dynamic balancing beads. 10 ounces in each of my tires and it rides super smooth. Bonus, you don't have to worry about losing wheels weights off-roading. You can find them at innovative balancing on the net. Hope this helps
Just made this exact switch about a month ago. Yes they take a lot of weight to balance but I feel like that's all relative. After all its 5" taller than the stockers that people use as a baseline for comparison and they probably weigh close to double? Not really surprising that it takes what it does to balance them.
Dyna beads never heard of them. I have equal balancing sand in my km2's and it's awful still get vibes all the time. And the guys at the balancing shop said they couldn't balance my km2's with weights, that's why they used sand. I hope the dyna beads are better then the sand. But hopefully just weights will do it for me with MTR's
Thanks for the responses so far everyone!
