37's on stock d30
Old Jan 1, 2012 | 02:55 PM
  #21
CACHE KRAWLER's Avatar
Good thread you have going here. It's nice, straight and to the point. Thanks all for the info.
Old Jan 1, 2012 | 03:57 PM
  #22
jeep2007's Avatar
My D30 is gusseted on 4:10 and holds fine. It more depends on driving style how often your gonna break something or if you do.
Old Jan 1, 2012 | 05:16 PM
  #23
MarvinMWJT's Avatar
I have been running 37's on my D30 for over a year. I try and wheel at least one weekend a month. Sometime hard, sometimes easy, it all depends on if the wife is with me. Gussetted and still running the factory 4:10s. The key is to know your weekness and limits. Wheeling is just like work...smarter not harder!
Old Jan 1, 2012 | 08:03 PM
  #24
Hodge7467's Avatar
Do you have a stick or auto? I have 5:13's and am going to 37's alittle worried about my gearing.
Old Jan 2, 2012 | 09:15 AM
  #25
Hodge7467's Avatar
Another question, so my plan is to sleeve and gussets I know the gussets are welded on but unsure about the sleeves. Is it a simple pull the axels and slid in the sleeves or are they welded in place? Thanks again for all the help
Old Jan 2, 2012 | 09:42 AM
  #26
Olean NY Jeeper's Avatar
They r welded. Not a easy install
Old Jan 2, 2012 | 10:03 AM
  #27
Hodge7467's Avatar
Ok so maybe just the gussets for now.
Old Jan 2, 2012 | 01:13 PM
  #28
gimp_dkd's Avatar
There are sleeves available now that do not need to be welded. I believe there's a couple of recent threads on them
Old Jan 2, 2012 | 06:13 PM
  #29
ridemx's Avatar
Originally Posted by Kevlarjk
I've been running the Kevlar 37 on my d30. For a while now With 5:13 The funny thing people don't realize is the axle tubes and the Cs are the same as the d40. The only thing different on the factory axles is the differential size. A Smaller ring and pinion. You will be fine if you don't wheel it. Anyone who is running a stock D44 or D30 should sleeve and gusset it if the wheel it After 37s. Hell even after 35s. And for people who don't think d30 are he same then why the hell are the sleeves and gussets you buy from Evo or any other company the exact same size. They will fit both axles. Trade the dude. You will love them. But then again be carefully wheeling it. And that goes for you d44 guys too. Here's a pic or two of mine. Nothing except for the spring perches are factory. All custom built.
Ok so they're the same housing?? Might be a stupid question but is there a way to make the 30 a 44?? Would it be more cost effective than buying a 44?
Old Jan 2, 2012 | 06:29 PM
  #30
sringer's Avatar
I have a d30 with 35's going to 37's soon. It will be fine. Sleeve and gusset maybe. But you will be fine. Tons of these threads floating around. Go for it!
I am here: http://maps.google.com/maps?ll=48.430918,-114.341932
Sent from my iPhone 4s using Verizon 3G
