5th Gear Grind
Old May 18, 2008 | 02:03 PM
unimog2's Avatar
Default 5th Gear Grind
Posted a few months back about grinding from 4th to 5th gear above 2500rpm. 3"bd lift, 35" Procomp MT's and 5"13 gears. Any thoughs and or what have you done to correct?
Old May 20, 2008 | 04:35 AM
2climbbig's Avatar
your sychro's for 5th are bad.
Old May 20, 2008 | 04:46 AM
GadgetFreek's Avatar
Same issue here. I found if I hold the clutch in just a second longer before making the shift, I do not get the grind.
Old May 20, 2008 | 07:51 AM
HarryBallz's Avatar
Hmmmm, sometimes I try to shift without the clutch, and 4-5 is usually not happy. I don't try that one anymore.
Old May 20, 2008 | 01:37 PM
unimog2's Avatar
Has this been an issue for you? Seems a bit strange that 5th gear syncro is bad?
Old May 20, 2008 | 04:49 PM
cjbischoff's Avatar
I get the grind from 4th -> 5th and I am not shifting that quickly, but if I slow it down (2-4 seconds) no problem. Took it and the dealership said they could reproduce the issue, but I can every time.
Old May 21, 2008 | 01:37 PM
unimog2's Avatar
you running stock or with a lift? Sounds like the dealer doesn't want to do the warrenty work.
Old May 22, 2008 | 10:44 AM
cjbischoff's Avatar
Stock, but I will have the issue resolved prior to the lift install so they that dont pull that out as a possible issue
