Acceptable pinion angle?
i posted a picture of my pinion angle above.
i want to know if my pinion angle is acceptable for a double cardan. i dont have an angle finder nor am i anywhere near my JK at the moment...i also do not have adjustable rear upper arms.
i would like to avoid having to buy rear upper arms since that would just double the cost of adding an aftermarket driveshaft. so im hoping you guys who do have aftermarlet shafts can eye ball it for.me and tell me what you think.
Looks to be inline with the driveshaft.
Since the axle rotates back (pinion rotates up) under acceleration, you might see some recommendations to extend the lowers a tad to drop the pinion 1 degree from inline. But should be fine as is.
Is the pinion angle supposed to be inline with the drive shaft or the back of the t case. I have a standard drive shaft on my jku with adjustable uppers and lower but have been given advise that the pinion should be inline with the t case. Thanks.
