Acceptable pinion angle?
We have a JK with the almost identical set-up. We've used it primarily for testing our JK ProGrip brakes, but it has wheedled quite a bit. The CV's are very tolerant of angle deviation. I totally get the on-trail repairability of the old-school u-joints. The Tom Woods guidelines will have to be implemented if you go to the 1310 Dshafts. So plan on at least one set of adjustable control arms in the rear. I would consider the lowers, because you may be able to better set the axle position (a little back) to compensate for your lift, as well as the pinion angle.
FYI - We are still running the stock driveshaft in the rear of that JK.
Thanks for running the Dynatrac Ball Joints. We deeply appreciate your recommendation to others.
btw i have a PR44 Unlimited and i love it
We have a JK with the almost identical set-up. We've used it primarily for testing our JK ProGrip brakes, but it has wheedled quite a bit. The CV's are very tolerant of angle deviation. I totally get the on-trail repairability of the old-school u-joints. The Tom Woods guidelines will have to be implemented if you go to the 1310 Dshafts. So plan on at least one set of adjustable control arms in the rear. I would consider the lowers, because you may be able to better set the axle position (a little back) to compensate for your lift, as well as the pinion angle. FYI - We are still running the stock driveshaft in the rear of that JK. Thanks for running the Dynatrac Ball Joints. We deeply appreciate your recommendation to others.
Do these lines look to be ballparked in about the right positions? Stop over-thinking, you'll give yourself an aneurism or high blood pressure or something it...
