Adj front toe in/out alignement
Old Jan 18, 2013 | 04:43 AM
JKingAround's Avatar
Caster with 4" lift and 37s should be around 7+ in the front what should it be in the rear the 4.2+ the stock number or should it be the same as the front ?
Old Jan 18, 2013 | 05:42 AM
planman's Avatar
Forum Tech Advisor
7 degrees caster on a 4" lift will destroy your front driveshaft. You want to be at about 4.2-4.5 degrees in the front.
Rear caster does not apply to a JK as an alignment spec. Instead, the issue of concern is the rear pinion to driveshaft angle.
Where are you getting your information?
Sent from my iPad using Tapatalk HD
Old Jan 18, 2013 | 05:58 AM
From Eddie way of life in the top post above
Old Jan 18, 2013 | 06:18 AM
planman's Avatar
Forum Tech Advisor
He changed his opinion but never updated the FAQ.
You want factory spec caster with a 4" lift--especially with an aftermarket front driveshaft.
Old Jan 19, 2013 | 02:37 AM
Coll thanks I thought it was around 4.2 until I read the thread above you keep me from a big mistake i was at the ailment shop when I got your rebuttal
Old Jan 19, 2013 | 02:42 AM
Cool.........
