Advice...
Old Nov 4, 2012 | 07:58 AM
BlackdogJK's Avatar
Default Advice...
So I took all the carpets out of my jeep. Carpets hold moisture and moisture leads to rust. Anyone know of a good DIY rhino liner type product to coat everything? I'm not interested in removing the entire interior (seats / panels) nothing ever goes back together as tight.
Old Nov 4, 2012 | 11:32 AM
BlackdogJK's Avatar
Gzbzjjxnxnxnxnxxbxnxnxnx
Old Nov 4, 2012 | 03:57 PM
_JK Outlaw_'s Avatar
Duplicolor makes a good spray liner. If you want roll on the only one I know of is Herculiner.
Old Nov 5, 2012 | 09:04 AM
Rooster76's Avatar
I would HIGHLY recommend raptor liner. It will look professionally sprayed. Here is my write-up
https://www.jk-forum.com/forums/jk-s...hreads-238739/
I'm not trying to be a dick here, but duplicolor and herculiner both will fade. I personally wouldn't use either. If you need to roll a bedliner I would use Monstaliner. It looks harder to get a truly pro sprayed look though.
Old Nov 5, 2012 | 01:20 PM
BlackdogJK's Avatar
Great thanks a lot guys. I'll look into this.
