AEV 2.5" Install
Old Aug 29, 2015 | 03:43 PM
WillysWheeler's Avatar
Kodiak864, Yes you are correct and it is ft lbs and I updated the posts.
Old Aug 30, 2015 | 04:01 AM
Almost There's Avatar
Originally Posted by PsychoCupcake
Pretty sure all of the JK bolts are 10.9 which is the metric equivalent. No need to replace those.
It's more about the material (zinc) & design (shouldered), and less about the grade.
Northridge 4X4® Jeep JK Grade 8 Hardware kit - GRADE8
Old Sep 2, 2015 | 03:31 PM
doogietj's Avatar
I installed the exact same setup a couple of years ago. I went with the bolt kit from northridge. All about the shouldered bolts. I recommend 2 ratchet straps, you might need some help getting the control arms into the geometry brackets. I did.
Old Sep 2, 2015 | 08:05 PM
Kodiak864's Avatar
For less than $50, why not? Guess I'll add when I order the wheels on Friday!
Old Sep 7, 2015 | 03:30 PM
Kodiak864's Avatar
Rear end done today.....can't work on front til Friday.
will add bolt kit from Northridge and Geo brackets as well.
Easier than I thought, but definitely follow the instructions, in order. Hahahah
Old Sep 7, 2015 | 05:08 PM
Pape's Avatar
Make sure you have a spare upper control arms bolt and nut as I was unable to remove the one on the frame side and decided to cut it instead of fooling around whit the exaus line
For inserting just do reverse and insert via the frame.
Be sure to check all torque 1 week after installation, the fast way to do this is make a trace on each final torqued bolts this way you know when they are loose or if it was torqued in the first place
You'll see the setup is great for DD
Old Sep 14, 2015 | 06:33 PM
Kodiak864's Avatar
Got it done over the weekend........
Old Sep 14, 2015 | 07:07 PM
Pape's Avatar
So how do you love the ride ?
Old Sep 14, 2015 | 07:22 PM
Kodiak864's Avatar
Less than 100 miles, but great so far!!!
Old Sep 14, 2015 | 07:23 PM
nukeneck's Avatar
Looks good!!! This is mine with same size lift
