aev beadlocks with toyos 37 13.5 rubbing ?
Old Dec 2, 2009 | 07:57 PM
john531's Avatar
Default aev beadlocks with toyos 37 13.5 rubbing ?
how much rubbing is expected. just recieved my toyos and havn't mounted them on the aev with 4.7 back spacing. dont want to use spacers so options ?
Old Dec 2, 2009 | 08:14 PM
jeepnick's Avatar
I don't think any with 4.5 backspacing
Old Dec 3, 2009 | 05:39 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by john531
how much rubbing is expected. just recieved my toyos and havn't mounted them on the aev with 4.5 back spacing. dont want to use spacers so options ?
the 13.50's are very wide and 4.5" of BS is way too much for them. you will see a lot of rubbing at a full turn unless you install wheel spacers or, add a bunch of washers to your steer stops as mentioned.
Old Dec 3, 2009 | 05:40 AM
jeepnick's Avatar
my bad, thanks for the correction
Old Dec 3, 2009 | 05:47 AM
JKDinker's Avatar
Also watch your swaybar disco bolts on the top. Had those wheels and ripped a inside sidewall on a brand new BFG KM-2 37" tire wheelin in the Rubicon. Driver side came up on a rock, stuffed it in the fender and POW! Bolt head threw the sidewall. Toyo's are way wider......My 2 cents. Wheels look cool though! Got lots of compliments on them.
Old Dec 3, 2009 | 06:17 AM
john531's Avatar
thanks for the replies. should of started this post b4 I bought the tires.
backspacing is actually 4.7 . decision new wheels or exchange for km2 or spacers
Old Dec 3, 2009 | 06:19 AM
wayoflife's Avatar
JK-Forum Founder
keep the tires as they are simply the best out there - at least, in my opinion anyway. as far as the wheels go, keep em and just get wheelspacers.
Old Dec 3, 2009 | 07:03 AM
jdahlum's Avatar
Hmm, I've got 12.5 inch ProComps on ProComp wheels with 4.75" of backspacing and I have a set of Toyo's being delivered tomorrow. I went and measured stop to stop last night and it appears I have plenty of room for the 13.5" Toyos. Am I missing something? It really looks like everything is going to fit just fine on my rig but I could be totally wrong!
Old Dec 3, 2009 | 07:13 AM
wayoflife's Avatar
JK-Forum Founder
it's not just the wide width of the toyo's that makes this a problem but rather, it's also the fact that they are a very tall 37.
Old Dec 3, 2009 | 07:30 AM
jdahlum's Avatar
Gotcha! Thanks for the PM reply as well. I think I decided to go ahead and bite the bullet and just go with the EVO Lever in the rear as well
What's the smallest amount of spacer I get away with? I think the smallest I've seen is 1.25". Will that work?
