AEV Drop Brakets
Old Jan 17, 2013 | 03:31 PM
  #21
AkimJeep2895's Avatar
Originally Posted by CatWrangler
I used some chain & a come along to pull the axle while inserting the bolt(s)
It's not a difficult add-on at all
thank you! I won't be needing the jack, jackstand, pitman arm puller, and drill bits however...correct?
Old Jan 17, 2013 | 03:40 PM
  #22
CatWrangler's Avatar
correct, that pic was for suspension lift but it has the CA tools on there(18-21mm wrenches & sockets)
vice grips are nice to have too
Old Jan 17, 2013 | 03:57 PM
  #23
MKW's Avatar
MKW
A small ratchet strap worked very well for me when I needed to move the axle a little to line up the CA bolt holes.
Mike
Old Jan 17, 2013 | 04:03 PM
  #24
Thank you all so much for the advice!
Old Jan 17, 2013 | 06:25 PM
  #25
Idaho's Avatar
Huh? These won't change the ride. Did I miss something?
Old Jan 17, 2013 | 06:59 PM
  #26
MrHooah04's Avatar
Uhm I have them on my jk and they've made an extreme improvement in drivability, I'd recommend them for sure
Old Jan 17, 2013 | 07:27 PM
  #27
malignant's Avatar
I just installed these drop brackets yesterday, very easy install only took ~1hr and I'd never done them before. This was on a 12, I had to use a long screwdriver to pry the upper control arm out of the stock spot and on the passenger side there was no issues with the bolt. You just have to lose the heat shield as it does restrict the ability to undo that bolt.
Old Jan 18, 2013 | 05:45 AM
  #28
Will I have to reinstall this heat shield?
Old Jan 18, 2013 | 06:37 AM
  #29
The shroud is there for a reason & it's purpose, i believe, is to protect the CA bushing from melting. Ultimately, you decide what you want to door don't do...
Old Jan 18, 2013 | 07:10 AM
  #30
malignant's Avatar
It's not really possible to reinstall with the drop brackets in place, as you can't get the bolt holding it back in as they are in the way. And with only one bolt to hold it, it would definitely fall off, so I just ripped it off on the passenger side. I imagine that since there isn't any plastic in that area to melt, just metal with the new brackets it is probably okay.
