AEV ProCal
Old 07-09-2016, 10:24 AM
Ripa777's Avatar
Default AEV ProCal
JKUR w 35s. Used AEV ProCal to program tires, axle etc. what about the front sway bar option? What should I run this at? On or off?
Old 07-09-2016, 10:34 AM
jedg's Avatar
Do you have an e-disco sway bar that you've replaced with something else? That option turns off the e-disco light on the dash. As in if you remove your e-disco, the light on the dash will flash until it's disabled.
Old 07-09-2016, 11:43 AM
Ripa777's Avatar
Oooo. Thx. So if I did Currie anti rock then I would turn this off ?
Old 07-09-2016, 12:09 PM
YYJ-JK's Avatar
If you do any mod that removes the e-disconnect then you use the procal to stop the dash light from flashing at you. There are some quick easy manual disconnect options for when the e-connect breaks but need a procal to turn the light off
Old 07-09-2016, 12:27 PM
Ripa777's Avatar
Got it. Thx
Quick Reply: AEV ProCal
