AEV really that good?
Old Feb 14, 2010 | 02:29 PM
racer83l's Avatar
x-2... the cam bolts do not allow for much adjusting. ~2 degrees
Old Feb 14, 2010 | 07:09 PM
mkjeep's Avatar
I had to play with the castor a good bit for the double carden driveshaft not to have vibes in the front, also a slight adjustment to correct the right hand pull. Now if you have a stock front ds, not as much of a concern, but with a double carden, yes , fine tuning is desired.
Old Feb 14, 2010 | 07:10 PM
Piginajeep's Avatar
Originally Posted by oO_Rogue_Oo
Not sure what would make you say that. Cam bolts allow for dead on caster adjustment; just how “fine” an adjustment do you need; dead on is dead on. As far as control arms go; the AEV argument is that the stock arms are plenty strong and the stock bushings allow for a much better ride than what the aftermarket has to offer. Remember the stock bushings typically last well over 100,000 miles. However they (AEV) do recognize that some people do not like the premise of cam bolts; in that case they normally recommend an adjustable upper control arm as they are exposed to less stress than the lowers. In the case where you opt for an adjustable control arm the AEV lift only calls for ¼” shorter than stock arm.
Isnt AEV coming out with control arms?
Old Feb 14, 2010 | 07:18 PM
vogeljk's Avatar
Default Go with Teraflex
The 3" lift clears 35" tires no problem. The only thing i added was upper CA's
Old Feb 14, 2010 | 08:20 PM
Jeepnboy's Avatar
Yes. I heard it was because of the "online bs" causing customers to think they needed them; not because AEV recommends them. Obviously, not everyone has the same set up so those with different drive lines and such would need adjustment greater than the cam bolt. I am still on the fence about the cam bolt, but plan on trying to use it first before getting adjustable arms (yes I know about the issue of having to weld up the holes).
I wish AEV was not always back ordered on EVERYTHING... But IMO, they have the best desgined stuff, so I conitnue to wait.
Old Feb 14, 2010 | 08:58 PM
mkjeep's Avatar
I hardly think a company would go though the expense and trouble of developing control arms just because of "online bs". If they thought there was no room for improvement in their kit they wouldn't be making them. Also, they're losing out on a product they could be selling instead of having to refer to another company. They just ended up being late to the game on adj. ca's.
Old Feb 14, 2010 | 09:09 PM
bly109's Avatar
The issue of adjustment aside, factory lowers bend A LOT easier the a good after market arm. I bent a fr and rear lower on my first two wheeling trips with the jk. The front was a hard drop, but the rear wasn't and it still bent. I've dropped the jeep even harder on my clayton front lowers and they are still perfect. So internet bs isn't the only reason to run an aftermarket arm.....
Old Feb 14, 2010 | 09:17 PM
Jeepnboy's Avatar
AEV is only coming out with front uppers for the JK. They will not address the issue you raise here.
And yes, from an abuse standpoint, based on my research, you will not find a stonger set of arms than Clayton. Those are stout.
Old Feb 14, 2010 | 09:27 PM
Jeepnboy's Avatar
Unfortunately, all manufactures make products based on their consumers wants and desires and in this case, AEV missed the mark by not offering adj arms from the beginning. Based on what I heard, AEV, or at least some there, felt the consumers' want was based on "online bs".
As a generallization, it could be the best product available, but if the buyer wants something else, the offered product will be a financial failure. With todays marketing, products do not need to be the best to be the best selling.
Manufacturers make a lot of things that will make them money even though it does not make something "better" for the average consumer. Think about the Sahara or some of the other shiney accessories that Mopar offers. Few on this website would think these products make the jeep better, but it is what many owners will buy.
I am not saying there is no need for adj control arms. But not everyone buying them to go with the AEV lift needs them.
Old Feb 14, 2010 | 09:36 PM
bly109's Avatar
The clayton's definitely are tanks, but most aftermarket arms will handle abuse better then the stockers. And of course it all depends on how you use your jeep. For me stronger arms are a must since I mostly rock crawl. Someone who mostly sees mud or sand or the mall might not need then.
