AEV Snorkel ?'s
Old Feb 19, 2010 | 03:44 AM
  #31
YOke's Avatar
Originally Posted by YOke
You can get it with either top. It is $309 for prefilter, $318 for ram air.
clicky
I was a hair off on price, but only pennies.....
yoke
Old Feb 19, 2010 | 05:28 AM
  #32
maddygirl's Avatar
Originally Posted by mediamaxim
The bumper is a Smittybilt XRC with tire carrrier. The Hi-Lift is mounted with just some bolts, washers, and lock nuts. I used some rubber grommets over the nut and bolt. The entire mod took 5 minutes. The base of the Hi-Lift stays in the recovery bag and I have a quick release Cotter pin for it. Super strong. Didn't lose any clearance. NO rattle. Solid Solid Solid! Looks like it should be a factory XRC mount location.
That looks good but I never saw a hi-lift weather well enough to make it a fixture visible on the exterior of my jeep.
Old Dec 28, 2010 | 06:52 PM
  #33
CGnTtown's Avatar
Anyone know how high up past the top does the AEV snorkel sit?
Old Dec 29, 2010 | 02:29 PM
  #34
nachostheclown's Avatar
Originally Posted by Hkx3
Do you guys know if the AEV snork will work with RR mirror relocation brackets?
I guess Im almost to the point of what the hell do I have to cut/grind/weld/drill to make this work, as I threw away my original mirror mounts.
I tried it and there was no way the right side would work. If there is a way to do it I would love to see it.
Old Jan 4, 2011 | 08:12 AM
  #35
soulsaege's Avatar
Anyone? Am I going to chart new waters here?
good luck
Old Jan 4, 2011 | 01:05 PM
  #36
pettym's Avatar
The RR mirror relocations will not work with the snorkel. As for the height, on mine, its not any higher than the roof as the pictures show.
Old Jan 5, 2011 | 12:17 PM
  #37
Mantaray52's Avatar
The passenger side RR mirror relocation bracket won't work, but if you're just trying to stay legal, as long as you have a rear view mirror and one side mirror you're legal. You can forgo the passenger side mirror altogether. Plus the relocation bracket on the passenger side moves it far enough that it's practically useless anyway. you can only see about 2-3" of mirror if you're lucky.
