Air Compressor and Tank
Old Feb 29, 2008 | 06:24 PM
castor07jk's Avatar
Viairs web site shows a max. ambient air temp of 158 degress so putting the comp. between the rad. and engine. I will be doing a test this weekend to see what the air temp is between the rad. and engine. going on a run sunday so it will be the perfect time test it. I will post what i find.
Old Feb 29, 2008 | 06:27 PM
castor07jk's Avatar
Originally Posted by TurkeyFreer
Alright, so it seems I'm not alone here...Where have folks found they can mount the components? I'm not averse to mounting the compressor on the rear interior wheel well, but I really don't want the tank to take up all the rear storage room (girlfriend, dog, kids soon, etc.). Also, anyone have a good wiring / plumbing write up or diagram? I started my Jeepin' with CJ so I have a little know-how, but am a little nervous about an OBA system with the 12V and relays and pressure switches and oh my.
Just to say, this forum is awesome and has already helped me out tremendously!
I've seen a tank mounted on the drivers side between the frame rail and drive line. Can't remember what mag. it was in.
Old Feb 29, 2008 | 06:30 PM
TurkeyFreer's Avatar
Default Tank mount
Alright then - I'm going to climb under there with a tape measure and see what I find. I'll let you know....Thanks for the heads up.
Old Feb 29, 2008 | 06:41 PM
castor07jk's Avatar
Here is the part # and measurements of the tank that comes in the onboard air kits
PART # DESCRIPTION
91025 2.5 Gallon Air Tank
• Dimensions: 23.50"L x 6.00"W x 7.50"H
• Six 1/4" Ports
Old Feb 29, 2008 | 07:56 PM
USAF_GroundRat's Avatar
Here is my installation:
https://www.jk-forum.com/forums/show...224#post365224
Old Feb 29, 2008 | 09:24 PM
castor07jk's Avatar
Originally Posted by USAF_GroundRat
You need to replace those wire nuts with some good weather tight but connectors. Wire nuts are not designed for low voltage high amp draw(i.e. 12v d/c). They are designed for high voltage low amp draw (i.e. 110v a/c). you will end up with corosion in those pretty quick.
Where did you mount the comp?
