Air Pressure with 35's
Old Jun 2, 2013 | 11:25 AM
2011MMJK's Avatar
Default Air Pressure with 35's
I go pick up my 35's Tuesday they are 8ply. How much air pressure do most of you run to get even wear? I am running 16x8 wheels. Thanks in advance for any suggestions.
Old Jun 2, 2013 | 11:30 AM
Offroad_Elements's Avatar
Former Vendor
Look up the chalk test, this will let you know your ideal psi for even wear.
Usually 28-34 psi is the common range.
Old Jun 2, 2013 | 02:11 PM
kjeeper10's Avatar
Vet Army
Many factors. I run 25-26 cold in my 35x16's
Old Jun 2, 2013 | 02:12 PM
Maertz's Avatar
X2 on the chalk test.. I run 20 psi cold but i have 10 ply...
Old Jun 2, 2013 | 02:15 PM
nthinuf's Avatar
I usually run 28-29 in mine. Any lower and they feel 'mushy', higher and the ride gets too stiff for my liking.
Chalk test them, and then experiment with a few psi's to see where you like it best.
Old Jun 2, 2013 | 05:21 PM
2011MMJK's Avatar
Worked around oe tires a long time never heard of a chalk test before. I will research it and see what I come up with. I was guessing 25 to 30 to keep the centers fron wearing.
Old Jun 2, 2013 | 05:49 PM
chknkatsu's Avatar
never did the chalk test, but on my KM2 i run 27lbs
Old Jun 3, 2013 | 01:33 AM
kjeeper10's Avatar
Vet Army
Chalk test will give you a close estimate but is not always going to be accurate. Running a 12.5 tire on a 8" or less wheel will cause the tires to balloon. Less pressure will be needed to achieve a good contact patch. Just remember... You don't want 100% treads touching. 1/4 or 1/2 on each side is ok.
if your tires are feathered or worn because of a alignment issue or whatever, the chalk test won't work.
Old Jun 3, 2013 | 06:15 AM
jkwade's Avatar
I chalk tested mine, and I fill them to 29, and re-fill them if/when they hit 27.
Old Jun 3, 2013 | 06:41 AM
Bo4Jeepn's Avatar
I run 35 nitto grapplers with Spyder bead locks. I typically keep them at 29psi. Unless off road, then ill drop them to about 5.
