Ajusting my odometer for 35's
Old Oct 5, 2008 | 05:37 AM
thissideup's Avatar
Default Ajusting my odometer for 35's
Ok, now that I have gone from the stock 32's to 35's How do I get my odometer to read correctly??
Old Oct 5, 2008 | 05:47 AM
cyberbrain's Avatar
the cheapest way is to go and buy a pro comp accu pro speedo programmer. I used it on my jk going from the 225 to 35's. its around 200. only part I dont like is they vin lock the programmer once you flashed it.
Also I found the programmer does more then adjust speedo. Your ecu adjusts your shift points, cooling, OD, esp/bias all on your speed. Trust me you will want to get it.
Old Oct 5, 2008 | 05:59 AM
jeepsanddrums's Avatar
I need to do this mod as well. I have not done my research yet, but I think the hypertech programmer will also do this for you.
Old Oct 5, 2008 | 06:02 AM
tgrt's Avatar
Former Vendor
Procomp one mentioned is just a rebadged version of the equivalent Hyptertech model. Hypertech also has their Max Energy model that adds all that and some performance tuning.
cyberbrain's Avatar
I also think the hypertech will do it. but there is a difference in price for a programmer and a speedo recal programmer. the pro comp programmer is around 400 bucks, my accu pro was 200. I probably could use the full fledged power programmer, but I ran out of money
Old Oct 5, 2008 | 06:20 AM
wrnglrguy's Avatar
Do what I do. Your speedo is going to be off about 3mph. Simply drive with your speedo 3mph or so lower than the posted speed limit. Adjust the pressure on the skinny pedal...it's free. Why spend $200?
Besides, if your speedo is off like that, you are actually putting LESS miles on your Jeep. That means when you hit say the 50K miles mark, it should really be at 60K or more. Just keeps up the value of the Jeep, having less miles on it.
Old Oct 5, 2008 | 08:13 AM
kockroach's Avatar
Note to self: Never buy used Jeep from wrnglrguy.
Old Oct 5, 2008 | 08:33 AM
lijeepguy's Avatar
is the programer really just a rebadged unit , that would be great
Old Oct 5, 2008 | 09:10 AM
ksk's Avatar
ksk
Im with him...
KSK
Old Oct 5, 2008 | 11:25 AM
blkpearl's Avatar
if you are running an auto it makes a big difference.....tranny will not be confused.....
