ARB Compressor gets really hot
Old Dec 21, 2009 | 07:59 PM
vogeljk's Avatar
Default I do have the heat shields
Originally Posted by horwitzs
Didn't you install the little heat shield that comes with it, so you can disconnect the hose without the burn?
I don't see how to install them. Do you have a pic?
Old Dec 21, 2009 | 08:14 PM
horwitzs's Avatar
Here's a pic that shows where it goes:
http://project-jk.com/wpg2?g2_itemId=144713
The heat shield comes in two halves, you press them together from opposite sides of the fitting to make a complete ring around it. You may have to put some zip ties through the holes to keep the two pieces together.
Then, all you have to do is press down on the heat shield, and the hose pops right off!
Hang on a few minutes, I'll dig up a pic of mine with the shield installed...
EDIT: OK here's mine. You can see where I used two small white zip ties to assemble it:
Old Dec 25, 2009 | 09:59 AM
vogeljk's Avatar
Default Thanks for the posts
Also thanks for the pic of the heat shield. You don't think those zip ties will melt do you?
