Aussie Locker
Old Feb 17, 2010 | 06:57 AM
river2c's Avatar
Originally Posted by ssunde1
so does this differentiating (clunking) also happen when just rollin in 2wd or just when the front diff is engaged?
You will notice it in two wheel drive also but only with very tight slow turns on hard surfaces. Not a big deal really. I've never noticed it while in 4WD because I've always been on loose surfaces with some tire slipage. The traction advantage off-road is amazing and definely worth the tradeoff IMO.
Old Feb 17, 2010 | 07:01 AM
hammerhead's Avatar
Originally Posted by BLK-JK23
well if you have a locker in the rear.... you will go father than people with just the fronts..
I'm happy with my rear LSD and I'm just looking to improve off road performace. I found this the other day and thought it was pretty good.
The guys with the Aussie Lockers are on the right track, as they're relatively cheap, and allow differentiation in turns while driving both sides, a real plus for street friendliness AND off road performance.
The MAIN reason rear over front lockers, if just getting one, historically, was that it is hard to turn with the front locked, as there's no differentiation to allow the outer tire to go faster...
...but the Aussie can differentiate, which helps on that front over a conventional locker.
A long time ago, a study was done to compare wranglers with just front, just rear, open diffs and twin lockers.
The study showed that the front locked jeep could do about 90% of what the twin locked rig could do, but the rear locked rig could only do about 60% of what the twin locker set up could do.
A lot of that is because the locker really only helps when you lose traction on one side....and, the rear typically has better travel, and, especially when climbing over things, is more weighted, and least likely to lose traction...
...whereas the front is more likely to slip, and therefore, more likely to benefit from the remaining tire being able to move you.
This meshes well with my experience, where the front locker guys seem to have a big edge, especially when you need to pull yourself up after the rear tires lose contact getting over a ledge, etc.
If I could only have ONE locker, I'd do the FRONT.
Old Feb 17, 2010 | 07:04 AM
river2c's Avatar
Originally Posted by hammerhead
Do you notice it clicking on the street in corners or just in parking lots at slow speeds. I really like how the Aussie works in 4wd. I'm just really concerned about click and clunk while in 2wd on the street. I'm not totally sold on the TrueTrac's offroad performance either, especially with 35's.
Just in parking lots with very tight slow turns. I really don't hear any clicking noises but I can feel it binding (clunking) when I lock the steering wheel hard right or left on tight turns.
Old Feb 17, 2010 | 07:05 AM
BLK-JK23's Avatar
id do both hahahahah... just to be that guy!
Old Feb 17, 2010 | 07:14 AM
river2c's Avatar
A LSD or selectable locker in the rear axle is nice to have if you need additional 4WD high traction in snow or icy conditions. You can leave the front Aussie locker disconnected (open) and just lock the rear axle. However, the BLD system works well on it's own.
Old Feb 17, 2010 | 07:16 AM
hammerhead's Avatar
I'll just be locking the front and will have to rely on my winch to help me out when needed.
Old Feb 17, 2010 | 07:42 AM
CA-JK's Avatar
The biggest time I notice it is when I pull into my parking garage. I have a full U-turn from the entrance of the garage into my parking space and I get a little clunking when making that turn. Other than that it is only noticeable when I am making 90 degree turns in parking lots or U-turns on the street.
The trutrac is great on level ground and mud but if you get a lot of weight on one wheel it will act just like the trac-lock you already have. JP magazine did a pretty good write-up on this last summer, I'll see if I can find the article...
Old Feb 17, 2010 | 08:06 AM
hammerhead's Avatar
Sounds like both of you are very pleased with the Aussie and that good to hear. Looks like I'll be happy with a Aussie as long as it performs like both of yours do. The video I watched of some other guys JK just freaked me out. I would really be pissed if that happens to me. I'm not sure how the TureTrac would handle the weight of 35" Toyo's and that has me concerned about it. I know the off road performance will not be anywhere near a Aussie but figured it would be better than nothing. As of now I'm liking the Aussie over the TrueTrac.
Old Feb 17, 2010 | 08:32 AM
jay01th's Avatar
I am also thinking about the Aussie Locker, especially when you read that a front Aussie will go about 90% of where a front and rear locked jeep will go. Above River2c said that you can leave the front open what does that mean. I thought the Aussie was engaged whenever the 4wd was engaged (front modle). But River2c leads me to think there is a on and off switch with it? Anyone know what it will cost to get one of these installed in the front of my Dana 30??
Thanks
Old Feb 17, 2010 | 09:18 AM
hammerhead's Avatar
When River2c talks about leaving it open he means leaving it in 2wd and relying on the rear LSD or locker to do the work. The guy that will be doing my gears charges $75 for a Aussie if done the same time as the gears. If you're not doing gears I would expect to pay for 2-3 hours of labor.
