auto trans shitfing problems
thats what im worried about...if i go to the dealer and they see its lifted that theyre gonna wanna go into a whole process to see if the lift caused the problem. knowing big companies they'll find a way to prove it was to save them from free work
When disconnecting the battery, always disconnect the negative terminal.
Applying tools to the positive terminal when the negative is still connected, can result in a spark/explosion if the tool hits a ground point while touching the positive.
Why wouldn't you want to see if they fix the transmission? The worst that can happen is they say no, which you sound willing to accept if you don't let them see it.
Update: so this morning I drove to work in limp-mode, about 60 miles (my beater honda is broken). Which was not fun. I got to work at 8 and took off the negative terminal and let it sit all day. When I left for the day around 4 I connected the the terminal and started driving. Much to my suprise it was shifting fine. Once I got on the parkway I was sure it would slip or shift hard and go back to limp mode...it didn't. I was able to do 70mph all the way home...that was babying it. I'm thinking/hoping everything cleared itself up like the first time
I just got my Jeep back this afternoon. Replaced torque converter. Pretty much everything that can go wrong in the tranny has been replaced over these 2 visits. The Dealer hasn't even mentioned the lift. The first time I asked if I needed bigger gears in the diffs (for the 35's), and he said the Rubi gears can handle it no prob. I hope you get it worked out with no drama.
