Balancing wheels: Weights inside or out
Old Dec 30, 2007 | 04:57 AM
150's Avatar
150
Fallen Hero
Originally Posted by WWJKD
R&R'ing/torqueing 24 bolts per wheel just to slide the tires around a quarter turn - I'll use that tidbit of tire info "next" time
What is ment by this statement?
Old Dec 30, 2007 | 05:08 AM
Renegade's Avatar
He has beadlock wheels and would have to loosen, then re-tighten all 24 bolts on the beadlock to spin the tire on the wheel.
Old Dec 30, 2007 | 05:13 AM
Renegade's Avatar
Originally Posted by benmar2000
SWEET!!! My dealership uses that balancer..
Cool. That machiine actually measures the "runout" of both the wheel and the tire and can tell the tech exactly which location (rotationally, if that's a word) to mount a particular tire on the particular rim to give the most round profile. I only had 1 of mine that could not be corrected for runout (not bad for 37's). It still balanced nicely, with less weight than the others.
Old Dec 30, 2007 | 06:57 AM
StevieRay's Avatar
Default Ceramic Beads
I have the ceramic beads inside my 35's and it has completely eliminated all the wobble on my Jeep. My 35's are on 17inch rims. I was having a significant wobble at 60 + MPH, but it is gone now.
That is my experience...
Old Dec 30, 2007 | 08:04 AM
john98026's Avatar
Default Answering your question
Your initial question was regarding placing the wheel weights inside or outside. The answer is both. As someone said earlier, this results in a dynamic balance and is a much better method of installing wheel weights.
Old Dec 30, 2007 | 10:20 AM
nukeman's Avatar
I too plan on having the "Bead Bags" used in mine when I have them mounted/balanced.
When I lived in Germany, all the shops used Nitrogen vs. air. They swore by it for proper balancing, but I always thought it only mattered at "Autobahn speeds" . Most tire shops here are using it now, any of you use it?
Old Dec 30, 2007 | 12:28 PM
150's Avatar
150
Fallen Hero
What part of Germany where you in?
Old Dec 30, 2007 | 01:24 PM
Jacks or Better's Avatar
Originally Posted by michaelt
Won't an internal balance product affect the 08 tire pressure monitering system?
Hrrmm I don't really know. Good question to throw out there.
I would guess that they wouldn't affect it. Pressure is pressure.
It wouldn't suprise me if it did though. I hear those things alert you for an arguably insignificant change in tire pressure. One guy I met said that his sensor goes off every morning and stays on until his tires warm up from driving.
Something like that would be great on a Cadillac running nitrogen in the tires. Nitrogen isn't affected by tempurature change as readily as air is..
I'm very glad I don't have pressure sensors in my JK. Sounds like it's been more a nuissance than a useful tool; at least in the wonderful world of wheeling.
Old Dec 30, 2007 | 01:43 PM
BaltChief's Avatar
You can't use beads or the like with the sensors......and you are right, they are a pain in the ass....
Old Dec 30, 2007 | 01:54 PM
StevieRay's Avatar
Beg to differ, mine were the easiest of all the upgrades I made. Never had any problems with them. Not sure about the sensors though.
