Ball Joint ?
Old Jan 15, 2011 | 02:26 PM
  #21
ronjenx's Avatar
Originally Posted by jrylb73
Ok so I am curious, my wife takes the jeep to a shop and they tell her the ball joints are bad. So then they check the alignment specs and they are all right it should be, so how could the ball joints be bad and the alignment still good. I would think if the balls joints were bad then so would the alignment. So the wife takes the jeep to another Shop for a second opinion and they say the ball joints were good
The thing about ball joints is, they won't always throw the alignment out when sitting still. Sometimes they will; it depends on what component in the joint is worn, and in what direction the wear is.
Bad ball joints will allow movement in the knuckles when the vehicle is traveling over irregularities on the road. In that case, the tires will not be tracking correctly while in motion.
That's why aligning your vehicle with bad ball joints is a waste of time and money.
As far as one place saying the joints are good, and another saying they are bad, the truth is, probably neither one actually measured the play in each joint.
Old Jan 17, 2011 | 11:10 AM
  #22
blazenjeep's Avatar
Originally Posted by northridge4x4
yes they can very common problem . Check out the dynatracs they are the only way to go imho . They are expensive but worth every penny
is there any other company out there then dynatracs that make them...
Old Jan 17, 2011 | 11:16 AM
  #23
wayoflife's Avatar
JK-Forum Founder
crown and raybestos makes ball joints too but, NOTHING out there is made as beefy as the dynatrac prosteers.
Old Jan 17, 2011 | 12:31 PM
  #24
blazenjeep's Avatar
IN THAT CASE TIME TO SAVE SOME MONEY... THANKS EDDIE...
