Ball joints?!
Old Apr 19, 2013 | 09:29 AM
Powderburn's Avatar
Default Ball joints?!
I need new balls! No idea which brand to go with. I have nvr bought them b4.
Open to any suggestions.
I have a 3.5 RK xfactor lift with 35" tires.
Gracias.
Old Apr 19, 2013 | 09:35 AM
planman's Avatar
Forum Tech Advisor
http://www.northridge4x4.com/shop/sy...et-ppm-8009-12
Best bang for the buck.
Sent from my iPad using Tapatalk HD
Old Apr 19, 2013 | 09:37 AM
Atlacatl's Avatar
I've got synergy on my list for when I need them...
hZZp:// synergy suspension .com/Synergy-Suspension-D30-D44-D60-Heavy-Duty-Front-Ball-Joint-Sets-p-26182.html
Old Apr 19, 2013 | 09:38 AM
Rob 12B1P's Avatar
Dynatrac if you have the scratch. Synergies are nice, I like the clear boots. Im running Alloy USA's but I will likely switch to synergies if these wear out. Moogs are lifetime warranty but wear out just as fast as the stock POS joints.
Rob
Old Apr 19, 2013 | 09:41 AM
Smashboogie 4x4's Avatar
Former Vendor
The ProSteer from Dynatrack is the best on the market, however they also have the highest price tag. The Synergy ball joints are definitely the best bang for the buck as planman previously said.
Don't reinstall stock or Moog ball joints because the labor will cost you in the long run.
PM us if you would like a quote on either set up.
Old Apr 19, 2013 | 09:50 AM
Northridge4x4's Avatar
Sponsoring Vendor
We have both the Dynatrac's and Synergy's in stock in both locations.
David
Old Apr 19, 2013 | 10:10 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Thanks to all for the props!!
Made in the USA!!
Dynatrac - Confidence to Explore®
High strength billet steel and heat treated bodies.
Super strong chromoly steel, heat-treated stems.
Effective seals prevent contamination and promote long ball joint life.
Fully greaseable on the truck.
Heat treated, precision ground stainless steel ball conforms to Military specifications.
Teflon coated internal wear points.
Fully-adjustable cup support protects against severe road impacts.
Reduce the cost of operating your truck.
Big increase in strength from the OEM ball joints.
Rebuildable without special tools – Lower repair costs.
Long Life – Less downtime, less tire wear.
Improves performance, handling and driver’s feel of the road.
Old Apr 19, 2013 | 10:29 AM
PhxRainey's Avatar
Either Joint listed here will work...it really comes down to budget.
Make sure you install the "bolt kit" at the same time from Northridge. I did and it made a big difference.
Northridge 4X4 Jeep JK Grade 8 Hardware kit
Old Apr 19, 2013 | 01:40 PM
ronin2120's Avatar
Vet Army
I just installed the synergy ball joints and I'm really happy with them.
Old Apr 19, 2013 | 01:58 PM
planman's Avatar
Forum Tech Advisor
I should disclose that I ran Dynatracs in my front Rubi D44 when I upgraded to 40s--before upgrading to D60s.
Also, I will soon upgrade the ball joints to Dynatracs in my 2012 Ram 3500 crew cab truck on 35s. I tow heavy and want the strongest ball joints.
I have installed the Synergy ball joints in our other 2 JKs--both 4 drs on 37s.
If you what the strongest, the Dynatracs are the way to go.
Although, when considering bang for the buck, at $200 per set, I doubt a person would blow through 3 sets of Synergy ball joints over the same lifecycle of a set of Dynatrac ball joints.
