Ball joints?!
Old Apr 19, 2013 | 03:03 PM
Riznoy's Avatar
Just put into Synergy ball joints a few days ago when I was getting my c gussets welded in.
If you plan of getting aftermarket axle shafts like RCV, you're going to have a clearance issue with dynatrac ball joints. That's why I chose synergy.
Old Apr 19, 2013 | 06:47 PM
PartySnake's Avatar
I know dynatrac has yet to sell a rebuild kit, i havent searched other sites yet but has anyone had issues or have had a set of the poly/synergy ball joints fail?
Old May 15, 2013 | 08:52 AM
pontiac31's Avatar
I have the Dynatrac's in my prorock44 and just had a u joint break on the trail. When I was repairing I had to pull the spindle to get the shaft to line up and the Dynatrac seperated after only one year. I am now in the process of trying to get rebuild parts and have waited a week only to find out they don't even have studs. Now I may have to wait another week and I am already out $200 for the parts (which I can return what is not used). Doing the math now I can get all new Synergy Ball joints for the cost of the rebuild parts,
Old May 15, 2013 | 09:43 AM
Northridge4x4's Avatar
Sponsoring Vendor
90% of the time when a u-joint breaks in yuor axle shafts it will take out the ball Joints also. This is not a defect in the ball joints. This is why I highly recommend RCV axle shafts. We have not had a front JK break that I can remember.
David
Old May 15, 2013 | 10:06 AM
pontiac31's Avatar
I agree, but upon inspection, both upper and lower were not touched. When we took it apart to replace the shaft the upper pulled down about 1/2" which pulled the lower on reassembly.
Old May 15, 2013 | 10:15 AM
Jumpmaster's Avatar
Dynatrac
Synergy
USA Alloy
I think anyone of these are good choices and much better than OE.
Old May 16, 2013 | 09:53 AM
pontiac31's Avatar
After tearing mine apart and putting it all back together. I found that the lower pressed down a bit out of place forcing the upper stud down with it. I followed the rebuild instructions on the upper to get everything back in place, then pressed the lower back up where it belonged. Put it all back together and everything is fine now, even checked alignment and everything is in spec.
I would like to thank Rob at Dynatrac for his patience with my calls and concerns with the problems.
Old May 16, 2013 | 10:28 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Glad it got worked out!
Old May 16, 2013 | 05:17 PM
webejeepin's Avatar
After 105,000 km on my OEM I they were just starting to get bad. After lift and tires I went with Synergy ... Very happy with them
Old May 16, 2013 | 07:46 PM
nismosis's Avatar
Just out of curiosity, how do you tell if they are getting bad?
