Ball Joints AGAIN
Any word on whether or not dealer is going to cover this? I just had a local fab shop make a beefier trac bar mount and they said i should check my wheel bearings and ball joints. They thought it should be under warranty but my dealer not so much.
My dealer says they are going to warranty mine, but I havent heard the final word yet. Like all things in this manner, it varies by dealer I'm sure. The tech at the dealer told me they have several other ball joint sizes (offsets) available if thats the need - otherwise a new steering knuckle should do it.
Edit: FYI, I merged these similar threads.
So should I tell the dealer that the tire shop found that my camber was off, or should I play dumb?
I feel like I should tell them so that they check everything, not just the ball joints that would cause my camber to be off?
Im going in Thursday.
Does anyone know who, if any, makes aftermarket balljoints for the JK? both sides are bad. replaced both before 12,000 miles and now again at 21,000 miles. dealer replaced the first time under warranty, but due to trail use and lift is reluctant to warranty again. Searched internet for some and came up empty handed. any help would be greatly appreciated.
From what I've heard and been told, there are no after-market ball-joints being produced, y-e-t. However, I recently had a nasty spell of w-o-b-b-l-e, and yes, it could be called D.W.; but anyhow, I swapped out all of my ball-joints. The shop that was assisting me contacted Dynatrac and reagrding said ball-joints, and they made a request that they be sent to them. Since none were being produced as after-market products, my "used" ball-joints were shipped to Dynatrac so they could use them as a starting point to engineer some after-market units. I have no idea what the ETA is on these new units, but hopefully something will eventually be produced.
UPDATE:
Just got back from the dealer. They are ordering all four ball joints.
However, they put it on their alignment rack and said my camber is only -.3 when the tire shop said it was -1.0. So now the question is, who is wrong?
Seriously, thanks to all contributors on this thread. I have a little play in my balls
and am going to have the dealership take a look this afternoon.
I'll update when mine gets out of the shop - hopefully an offset joint will do the trick.
Used as a DD but on weekends dirt roads rocks ect...
