BB Question/Clarification
Old Jan 3, 2010 | 05:36 PM
RubiDude's Avatar
Default BB Question/Clarification
I have been reading about the BB set up...and I was wondering...is this a body lift? More specifically, will I gain ground clearance to help me not hang up in the middle when going over high angle break overs? I have already determined from this forum that I am not interested in a 4" suspension lift, but I was wondering if the 2.5" BB would give me any more useful clearance on the trail? Also, I am correct that a body lift does not add to clearance, only to accomodate larger tires? Thanks all!
Old Jan 3, 2010 | 05:58 PM
Brian08JK's Avatar
a body lift raises the body off the frame. A BB or budget Boost is "Pucks" Placed under the coil springs.
Old Jan 3, 2010 | 06:15 PM
BBirish's Avatar
you are correct. the Budget Boost is a suspension lift and will raise the entire jeep giving you more clearance better breakover angle, etc. Body lift just raises the body to accomodate larger tires
Old Jan 3, 2010 | 06:23 PM
RubiDude's Avatar
Cool. With a BB of 2.5" I can expect to maintain my factory like street ride? Also, what about the levelling issue? Will this give the Jeep a more level look and no more nose-down profile?
Old Jan 4, 2010 | 08:12 AM
BBirish's Avatar
Yes the BB will maintain a factory like ride.
As far as the leveling issue i think that you will still have the same factory rake as both spacers are 2.5 inches. I added a 3/4 spacer to the front ones and it was perfect
Old Jan 4, 2010 | 08:40 AM
wazooz2424's Avatar
you can stack front spacers to level out the rake. remember, no lift will raise the axles off the ground, so you will still have to worry about it getting caught. bigger tires will raise the axle.
Old Jan 4, 2010 | 08:53 AM
HG07JKRubi's Avatar
Check with Teraflex on this. I think there was a recent design change to their 2.5" BB that now uses 2" spacers in the rear to help level the Jeep as opposed to the same 2.5" that the front is raised.
Old Jan 4, 2010 | 11:23 AM
RubiDude's Avatar
I think you are right...that is exactly what the guy who is doing mine said this morning! Can't wait to get it back!
Old Jan 4, 2010 | 12:10 PM
nthinuf's Avatar
A BB will not make the ride any more stiff/harsh/softer/plush/etc than your current ride quality. It will, however, affect the handling. As you lift further, your caster gets lower, which causes the handling to become worse. (flightiness, bumpsteer...) At 2.5", it is off enough that many people add control arms to fix it. It is a personal preference, and only you can decide if the handling is bad enough to warrant the expense of new arms.
Read this section in the FAQ's for a bit more info:
Q: What is Caster? How much do I need?
Old Jan 4, 2010 | 12:15 PM
IcyFridge's Avatar
So a 2.5" BB is basically a 2" lift.
