The Best!
Old Jan 20, 2013 | 06:22 AM
CajunTiger's Avatar
Default The Best!
Who makes the best 4.10 or 4.56 gears? I have some Yukon 4.88's not installed, but I will not install them due to fuel milleage. Its my DD. I must add that I have a 2011 JK 6 Speed manual. Just looking for a good brand since Yukon does not make either 4.10 or 4.56. Thanks guys and gals!!!!!!
Old Jan 20, 2013 | 08:52 AM
familytime's Avatar
JK Forum Regional Rep
4.88's are going to be too deep for your 6spd.Either 4.10's or at most 4.56's
Old Jan 20, 2013 | 06:35 PM
CajunTiger's Avatar
139 views and nuttin?
Old Jan 20, 2013 | 06:46 PM
swaite3's Avatar
I have nitro 4.56's installed on mine and they seem just fine
Old Jan 20, 2013 | 07:00 PM
CajunTiger's Avatar
Well Thank You Bro!... What year do you have and how is your MPG's?
Old Jan 20, 2013 | 07:14 PM
swaite3's Avatar
Mines a 2012 auto with 35x12.5 nitto trail grapplers, just got them installed last week so I have not done too much driving.
This is my results so far
15-16.5 mpgs
Cruising at 70-75 is much better now as I can use overdrive
Old Jan 20, 2013 | 07:17 PM
swaite3's Avatar
Btw as a side note I picked the nitro vs he USA standard that are cheaper because the USA standard are rebranded Yukon gears that are not up to spec
Old Jan 20, 2013 | 07:21 PM
CajunTiger's Avatar
Wow! I wish Yukon made 4.10 or 4.56, but thanks for the info! Won't be buying those!
Old Jan 20, 2013 | 07:28 PM
OverlanderJK's Avatar
What gears do you have now? 3.21's or 3.73's? In my opinion going to 4.10's will be a big waste of money. If you don't plan to go bigger then 35's then 4.56's will be ok but if you plan to go bigger then just wait.
Old Jan 21, 2013 | 01:55 AM
OH9JK's Avatar
JK-Forum Ambassador
A Spicer gear set would be the best. However if you want a ratio that Spicer doesn't offer then you will have to deal with aftermarket parts.
What is your end tire size goal?
You really only want to do this one time....unless you have buckets of expendable cash laying around
