best locker?
Thanks for the write up. Very thorough. But can someone explain to me why an auto-locker is invisible when installed in front while in 2WD? Is it an open diff when not actuated? I thought the auto lockers were mechanical and were always working? That doesn't sound right. Please explain. Thanks.
I want to install a Detroit in the rear, but with the snow and ice we have I don't think it would be safe to drive sometimes. It is my opinion the Trutrac is the best limited slip, but what do you guys think?
I've ran a lot of detroits in toyota trucks (light in the a$$ end, and blazers) In fact I would not ever waste my time and money on a limited slip. I owned the toyotas in AZ and PA and Southern IL. through many snow storms and plenty of ice, it's not bad and you learn how to drive it in short order. Do yourself a favor and if your gonna do gears in the future do the detroit locker and gears at the same time. My $.02
Newbie question: I'm new to lockers so I was reading through this thread (thanks Dynatrac) and am not to sure I understand correctly or not...
The stock JKU Rubicon e-locker is not from Eaton, but GNK...AND the GNK is actually stronger and more reliable than the D44 Eaton Elocker...correct...??
Correct- The Factory Rubi locker is from GKN not Eaton.
Correct- The factory Rubi locker is stronger than the Eaton D44 version. However, it may not be more reliable.
The Dana 3O Eaton ELocker is a great piece and probably the the best selactable option for a 30.
