Best shocks
Hi all,
I'm looking to improve the on road ride of my JKU and add a lift too.
My question is, what are the best shocks for this ?
I've seen that Rancho make an adjustable shock now, would this be a good way to go and are there any other adjustable shocks out there ?
Goatee
Goatee
Shocks are definitely a can of worms. The only limitation is your budget. The Rancho 9000 adjustable are a good inexpensive shock. However, you just have to figure that you get what you pay for.
If it's on road ride your looking for, then moving up to something with a reservoir would also be something to look into if your budget permits.
I currently have Bilstein 5100's which is also a good inexpensive shock. They would compare to the Rancho 7000. I got the Bilstein because I needed something inexpensive, around $85 per shock. Eventually when budget permits I plan to get something with a reservoir. The main advantage that will give you is if you take any fire roads or bumpy roads. It will also help for daily driving. It won't help much when rock crawling though.
Another advantage of more expensive shocks is that they're rebuild able. If you break one of the Rancho 9000's, you essentially throw it out and buy a new one.
Hi all,
Goatee
Goatee
By Goatee
"I'm looking to improve the on road ride of my JKU and add a lift too.
I've seen that Rancho make an adjustable shock now, would this be a good way to go and are there any other adjustable shocks out there ? "
Other than that, any two shocks which have similar valving, would feel the same.
Softness comes from the shock & coil combination, and the shock influences ride quality much more the coil does.
Fox, and others, offer shocks that you can adjust by simply rotating a knob. This eliminates the need to send the shocks (at least once) for re-valving. You can easily tweak the ride softness by yourself.
Just don't make them too soft, or the bump stops would be often hit.
By suicideking
"…..If it's on road ride your looking for, then moving up to something with a reservoir would also be something to look into….."
Typically, very expensive and soft-riding cars don't have shock reservoirs.
Reservoirs prevent shock heating problems.
The extra volume and cooling area of the shock fluid helps when shocks are required to work real hard in high ambient temperature and for a long time.
One of the examples for the benefit of reservoirs is Baja races.
On roads, reservoirs may begin to show their benefit only after hrs of continuous fast driving on bad roads in very hot weather.
I have Fox w/ reservoirs, because when I go to the desert in southern Israel, for many hrs of offroading in ambient temperature of 40+ Celsius, the reservoirs prevent overheating of the shocks.
"…..I plan to get something with a reservoir. The main advantage that will give you is if you take any fire roads or bumpy roads. It will also help for daily driving. It won't help much when rock crawling though."
By bbrown626
"The best setup may be the EVO bolt-on setup with King coil-overs. Anything else is probably a compromise."
While King is considered to be the best, I have yet to see Fox or OME fail. I've seen them fail only due to faulty installation.
Metal Cloak offer their 6Pak Long Travel Shocks, which look very promising. They are double shocks.
