Bestop trektop question
Mine did the same thing doors off no mirrors... Highway flapped like crazy and came loose couldn't see a thing pulled it tight then the support bar comes up clipped , I wrapped my straps around the bar and pulled it tight worked ok not right but effective luv the top but sure has some issues thinking of selling mine and going to a factory top set up
I used a few of the bungee balls...tarp bungees...and wrapped them around the roll bar and rear aluminum bar to keep the flapping to a minimum. It also prevents the rear part of the top from falling down.
Rotate the balls toward the inside and leave them on all the time. They don't get in the way at all.
These guys....
These guys....
IIRC there's no paint under the hinges and you have to cut the paint around the hinge. My tailgate hinges had rust under them when I was installing a Teraflex hinge.
Mine were frozen also every day I sprayed WD40 top and bottom worked the door back and forth up and down after a few days it broke loose after a couple more days they popped right up just took time I might have got lucky but it worked for my no mallets no jacks just time
What is it about the steel pipe that keeps it from flapping? The weight?
OK... I Love Trextop NX on my Unlimited.....but here is the only problem I have with it. When you are out and about and decide to remove the windows.....What do you do with them? How do you keep from destroying your windows????
