Big Time issues!!! Please HELP!!!
Old May 5, 2011 | 06:50 AM
WillyWonka10's Avatar
Default Big Time issues!!! Please HELP!!!
Alright where to start so in 2wd i have no issues but when it is cold it does make this sound once and awhile then goes away....
in 4 high this is the noise it makes when turning and going straight
in 4 low this is the noise it makes when turning and going straight.
Please help me diagnose this issues hoping you are not going to tell me it is the Transfer Case!!! could be the CV joint on the front because there is oil sprayed everywhere...
http://www.youtube.com/watch?v=9WYXed8MQw0
Old May 5, 2011 | 06:57 AM
wells's Avatar
Where is the oil coming from?
Old May 5, 2011 | 07:01 AM
TheKid25's Avatar
that sounds awful. is it only when turning? nothing loose under there?
Old May 5, 2011 | 07:09 AM
Hey guys it happens when going forward and turning.. the oil is right in line with the CV joint right by the Transfer case.. I am getting the rear replaced under warranty the boot is split on the CV joint but I think the front is Shot also
Old May 5, 2011 | 07:16 AM
wells's Avatar
Sounds like could be a bad driveshaft. You wont notice the noise in 2wd because there is no torque on the front shaft.
Old May 5, 2011 | 07:22 AM
Hey Wells that is what i thought i just wanted to confirm it wasnt a T-Case problem! well looks like it is time to go to a Tom woods DS or a Coast DS!!!
Old May 5, 2011 | 07:23 AM
i did crawl under the jeep there is VERy little up and down movement on the front DS but there is still movement regardless... maybe i will make Jeep replace the front DS also
Old May 5, 2011 | 07:37 AM
Yeah my boot is not torn but there is a bunch of grease right by the t-case right by the CV joint. i think it might be a bad CV JOINT GRRRRRRRRR here i will upload another clip I took of the drive shaft....
Old May 5, 2011 | 07:48 AM
Here is the Clip!
http://www.youtube.com/watch?v=SBlgwb-66Is
Old May 5, 2011 | 07:57 AM
Orangeav's Avatar
That sounds terrible! I sheared a tooth off the rear gear in an old 2wd truck that sounded a lot like that. It was like I was grinding up a metal can in the rear end. You going to get that fixed in time for Drummond?
