Big Time issues!!! Please HELP!!!
Old May 5, 2011 | 08:02 AM
fadeout's Avatar
that's drive shaft, I had the same type of noise when I ripped the shit out of the front one coming down off of a hard obstacle, in water no less.
Old May 5, 2011 | 08:04 AM
The_Yeti's Avatar
Maybe remove the front Drive shaft and then drive in 2WD and try 4WD if it stil sounds bad.... you know its not the DS.
I dont think you will have any problems doing this on dry pavement sense there is no force or torque on the front axle with DS removed.
(check with others before doing this i am not responsible if anything bad happens just something i would do on my rig)
Old May 5, 2011 | 08:21 AM
WillyWonka10's Avatar
Nope down for the count for drummond!!! I was going to drive down to Nashville TN just to get out of the state for awhile but i dont trust the jeep on a long journey.... time to order a custom front DS.... going to talk to David from northridge see what kind of deal he can throw me.. Dealership is already replacing rear because the boot is split also... so that will at least give me some time to get a upgraded rear ds... I am just hoping i am up and running for the Badlands trip on the 21st...
Originally Posted by Orangeav
That sounds terrible! I sheared a tooth off the rear gear in an old 2wd truck that sounded a lot like that. It was like I was grinding up a metal can in the rear end. You going to get that fixed in time for Drummond?
Old May 5, 2011 | 08:29 AM
Thanks for making me feel better i wish i broke mine doing something cool but i didnt... GRRRRR... What do you suggest TW drive shaft or Coast drive shaft? they are about the same going to shop around a little bit...
Old May 5, 2011 | 10:49 AM
Deepwater's Avatar
Before you buy the DS search this forum for transfer case exploding. There is a downside to double cardan drive shafts that you need to understand, especially because you are concernced about your transfer case.
Mike
Old May 5, 2011 | 10:58 AM
Abacabb's Avatar
It's the drive shaft. I had the exact same problem.
Tom Woods drive shafts.
Old May 5, 2011 | 11:21 AM
Widowmaker's Avatar
Ok, I feel bad now that your freaking out. It's my fault, at the suds n grub I put a playing card in your spokes.
Old May 5, 2011 | 11:37 AM
Went with the Coast front drive shaft!!! ordered up and going to be at my door step tomorrow morning!!! cant wait to get rid of this God awful sound!!!!
Old May 5, 2011 | 11:39 AM
YOU BASTARD!!!!
Old May 5, 2011 | 11:43 AM
MTH's Avatar
MTH
Wait, let me get this straight . . . .
So you lifted a two door auto with a 2.5" TeraFlex kit--which famously adds more than 2.5"--and tore your driveshaft boots. And you managed to convince your dealer this should be covered under warranty??
You sir must be the most effective negotiator in history. Or maybe a really hot chick. How did you do this??
