Big Time issues!!! Please HELP!!!
Old May 5, 2011 | 12:09 PM
  #21
mpkelley20's Avatar
Originally Posted by MTH
Wait, let me get this straight . . . .
So you lifted a two door auto with a 2.5" TeraFlex kit--which famously adds more than 2.5"--and tore your driveshaft boots. And you managed to convince your dealer this should be covered under warranty??
You sir must be the most effective negotiator in history. Or maybe a really hot chick. How did you do this??
My brother in law got his replaced on his JKU with the same 2.5" lift and 35's. Half his front end is bent to s**t from obvious wheeling but the dealer still replaced it under warranty! The next trip out he wrecked his driveshaft again but hasn't brought it back to see if they will replace it again...somehow, I doubt they will this time! LOL!!
Old May 5, 2011 | 12:24 PM
  #22
WillyWonka10's Avatar
I am running a 2.5 inch lift with 33" tires i do not thing my Pinion angle is not all that bad. so i should be fine for now but the control arms are on the list!
Originally Posted by Deepwater
Before you buy the DS search this forum for transfer case exploding. There is a downside to double cardan drive shafts that you need to understand, especially because you are concernced about your transfer case.
Mike
Old May 5, 2011 | 12:34 PM
  #23
08yellowx's Avatar
Check to front axle u joints they too will make that sound.
Old May 5, 2011 | 12:52 PM
  #24
Yeah just went with new shaft.... see if that is causing the issue! the stock two door shafts are CRAP!
Old May 11, 2011 | 04:20 AM
  #25
Hey Everybody!
The new front driveshaft solved all of my Problems... I want to Thank David from Northridge for getting me my drive Shaft ASAP!!! you are a life saver
