Bigger tires,now steering feels funny....
Old 10-11-2012, 02:00 PM
jkmadness's Avatar
Default Bigger tires,now steering feels funny....
Let me start by saying i read the whole thing about caster and what not,but what i cannot understand is that all i did was swap my stock 17"moabs with 255/75/17....with 17x9 black addicts/295/70/17 nittos trailers.
I understand i went up on diameter and they are 2 inches wider.....does the toe need to be adjusted any thoughts would be appreciated.
Old 10-11-2012, 02:03 PM
skibovr6's Avatar
You need to tell us more, what's funny? With a wider or taller tire handling characteristics will change for sure.
Old 10-11-2012, 02:11 PM
jkmadness's Avatar
shifting lanes at highway speeds feels touchy (squirrelly),like i have to hold on to the wheel afraid im going to oversteer..
Old 10-11-2012, 02:16 PM
mattgt5's Avatar
Wider tires can have a floaty feeling at highway speeds. If you didnt lift, i would start with tire pressure check and a balance check
Old 10-11-2012, 02:19 PM
c17loadmaster's Avatar
Grab a tape measure and search project JK for the do it yourself alignment. I had a toe out condition and fixed the flighty feeling with an alignment
rinkishJK's Avatar
I would check your toe, and tire psi. I run my 35's at 25 psi, and have played with it a lot and this is best for me.
Old 10-11-2012, 02:20 PM
jkmadness's Avatar
I didnt lift yet,but i have a TF 2.5 coil kit coming and i also bought the adjustable front lowers to dial the caster back to normal...
Old 10-11-2012, 02:23 PM
jkmadness's Avatar
wow 25....mine have 32 psi...could that be it...
Old 10-11-2012, 02:53 PM
Opalgem's Avatar
Probably air pressure if all you did was change tire size. I have had cars go like this and started changing idler arms, drag links, center links...ETC and all the while it was tire pressure. Just go down a couple lbs at a time. You would be surprised what a difference it makes sometimes.
Let us know how you make out?
Old 10-11-2012, 02:57 PM
jkmadness's Avatar
I will do it tomorow and keep you posted...Thank you
Quick Reply: Bigger tires,now steering feels funny....
