Body roll
Old Apr 13, 2015 | 04:11 PM
TaylarsJK's Avatar
Default Body roll
First things first, here's how my jeep sits now:
JKU, 2.5" Metalcloak springs, Old Man Emu Long Travel shocks, front Metalcloak track bar (not raised), rear OEM trackbar (raised), rear OEM sway bar links moved to front (parallel to ground), and extended links in the rear (need to be a few inches longer to have the sway bar level).
I've been getting a good amount of body roll in corners, changing lanes, really anywhere. I need to get new rear links so that it doesn't flip when flexed, would this also improve my body roll? If not, what can I do to improve it?
Old Apr 13, 2015 | 04:34 PM
DJ1's Avatar
DJ1
Former Member
What psi you running on the tires?
Old Apr 13, 2015 | 06:27 PM
sea bass's Avatar
You have front links installed right? That seems strange - i experience less body roll with the lift than before even when running the stock wheels for a while
Old Apr 14, 2015 | 03:44 AM
TaylarsJK's Avatar
28, they're 35 Toyo MTs
Old Apr 14, 2015 | 03:55 AM
TaylarsJK's Avatar
Yep I do. Do you also have the MC sway bar drop brackets installed in the rear? I'm not sure if sway bar angle affects body roll or not
Old Apr 14, 2015 | 05:14 AM
TaylarsJK's Avatar
Here's my rear sway bar for reference
Old Apr 14, 2015 | 05:43 AM
sea bass's Avatar
I have the MC longer links in the rear. Angle might have some affect but not much I wouldn't think. Are you sure it's body roll that you're experiencing and not the flighty steering of improper castor?
Old Apr 14, 2015 | 06:05 AM
TaylarsJK's Avatar
Forgot to include that I have AEV control arm brackets too. They're in the 2.5" hole, I could set them at the 3.5" hole if that would help. I was going to anyway, but need to find ratchet straps to help line up the holes.
Old Apr 14, 2015 | 08:00 AM
DJ1's Avatar
DJ1
Former Member
It looks like the only thing really left to correct are your rear links. I've got the AEV 2.5" which still uses the OEM rear links but I've also got the shorter wheel base on the 2 door and there's less weight to shift around...
Old Apr 14, 2015 | 11:56 AM
TaylarsJK's Avatar
That's what I'm thinking, just trying to figure it out before I start spending money. Thanks for the help
