broken front trackbar bracket help
i would install the renfocemnet brackets before the stock brackets break . alote easier and cheaper to do it before they break.. ive heard stories of stock jk track bar brackets breaking off. their are alote of different brackets to choose from . i am very happy with the JKS ones. very strong , im going to get the C2 Front Axle Reinforcement Gussets next.
My holes were wallowed so I had to weld them, should I just add more welding to the stock brackets?
One of the cheapest, easiest gusset I added to the track bar is a small tab running from the coil spring bracket to the top of the track bar bracket.
What kind of welder to you have?
MOST (not all) cases of trackbar bracket failure are from the extra torque put on the bracket by the extra "relocation" bracket.
The extra length of the additional bracket adds torque (rotational force at a distance)
Its like when you add a breaker bar to loosen a stuck nut.
with your TF adjustable trackbar, it should have been connected directly to the OEM bracket. (right?)
The result will be significantly less torque on the bracket and therefore less chance for failure.
That being said, I ordered the JKS adjustable TB AND the front and rear braces from JKS.
once youve experienced a TB bracket failure/ death wobble/ grueling ride home at 20-30mph, the parts dont seem so expensive...
good luck
Yeah well mine broke turning a corner in a Wal-mart parking lot. I called my wife and had her bring my welder out, The manager there let me use their outlet. It's the metal that breaks in half, not the weld joint. It's like the guys at Jeep didn't think anyone would jack it up and put bigger tires on their ride.
