Bumper of Shame
I've got the ARB front as well, but no winch yet. I've thought about checking with a local machine shop to have them machine a solide piece of aluminum the same opening on the ARB and mill out the slot for the winch line.
Only downside is it be one large piece of aluminum. You could actually have them machine a larger diameter edge for the fairlead opening.
1st we have companies making accessories for our Jeeps, now we need someone making accessories for our accessories.
Would it be possible to mount the fairlead on the inside of the bumper facing the winch then that black hawse on the outside? That would protect the rope from touching the bumper between the winch and hawse, then the hawse should protect the rope from rubbing the front of the bumper depending on how far it sticks out.
Just an idea?
Just an idea?
Just an idea?
Just an idea?
Hopefully before I head up to the Coal Creek ride Dec 27-28 (It's in The South sticky section). At the moment, it's actually temporarily mounted on Wilbur while I figure out wiring, etc.
Bumper and Winch Mounted
Well, after installing the ARB I've decided I should have titled this thread, "Bumper of Pain". For the most part, I like the way everything turned out, but whew, this bumper was a pill to install. Eventually had to pull out a drill and start enlarging mount holes of factory frame in order to achieve enough tolerance to allow all the bolts to be attached (you might check yours if you had a shop do it, as they may have been tempted to leave off one or two).
Mounted bumper first, and then was able to easily install Superwinch EPi9.0S (bumper-winch bolt tolerance was very tight - 1mm either way, and it was a no go . . . but with everything perfectly aligned, the install was possible).
Anyway, here's a quick pic I took today of bumper and winch. Need to mount lights next, but already fit checked and all looks good.
