Can I put this Dana 44 on my "X"
Old 02-06-2014, 12:11 PM
shadowmonstr's Avatar
Default Can I put this Dana 44 on my "X"
I have an 08 Jeep Wrangler X with a Dana 30 front and a Dana 44 rear end and a 3.21 gear ratio I fried my front differential and I want to upgrade it I have a Man 6-speed manual and a 4 inch lift and 33 inch tires both current diffs are next gen and the rear is HD. I found these from Mopar.
Crate Axles
Part # P5153825AF
Category: Performance
MSRP $2395.00 Price may vary by dealer
Upgrade to the next level of Off-Road Performance. All axles are shipped with the current suspension mounting brackets installed. These axles are completely assembled.
Additional Details: Dana 44 Crate Axle, Front 4:10 eLocker
Crate Axles
Part # P5155359
MSRP $41.20 Price may vary by dealer
Additional Details: E-Locker Wiring Connector and Harness for DIY installation, Switch not included
will this bolt right in and what other parts will I need to get to finish the job such as rear gears
Old 02-06-2014, 12:22 PM
Shadow's_Jeep's Avatar
Yes this would bolt right in, you would have to change rear gears to match. An change your rear carrier to 3.73 above.
Old 02-06-2014, 12:42 PM
Can you suggest gears and maybe a link if its allowed. Thank you for replying. Also do I need new drive shafts? Like your username by the way. And if I'm reading the axle info that front axle should come complete with diff gears and shafts right? Also what about "u" joints do I need to change those.
Old 02-06-2014, 12:51 PM
nthinuf's Avatar
Call and double check, but it should come complete, locker/gears/factory ball joints/inner & outer shafts + joints. Then you re-use your current hubs/brakes.
There are many different gear mfg's, but for a JK, the name on the box doesn't matter a whole lot. Compare price and warranty and get whatever you want. As long as they say 'JK' and are 4.10 to match the front. Check with any of the sites vendors for pricing. ( 4wd, 4ws, offroad elements, river city, quadratec, rebel, northridge, etc, etc)
Old 02-06-2014, 01:37 PM
Contact Dave at Northridge 4X4 . He is a vendor on this forum , he can answer all your questions. You find him in the Vendors section. Or call him at 866-601-5340.
Old 02-06-2014, 01:39 PM
cctroupe11's Avatar
Someone correct me if I'm wrong, but the front carrier is the only one you would have to change for 3.73+, right? So he would be good to go aside from changing the rear gears to 4.10.
Old 02-06-2014, 01:43 PM
He is putting a complete Rubi d44 front in , he would need to change the rear carrier to 3.73+.
Old 02-06-2014, 01:58 PM
nthinuf's Avatar
Correct - d30 with 3.21's would need a new carrier. (new axle instead, so not an issue)
Incorrect - The rear d44 carrier is fine, just need new gears to match the front, and an install or master kit for it.
Old 02-06-2014, 01:59 PM
JKBANDIT55's Avatar
Im sure the front and rear gears need to be matching. When he throws it in 4x4 it will cause problems. When I blew my front axle in my old 07 I got it replaced and the dude didnt check that I had 4.10 gears put in. he put in stock 3.21 gears in the front. When In 4 wheel drive the Jeep wouldnt run correctly. Tires moved at a different speed and torque and caused all kinds of noises.
Old 02-07-2014, 11:21 AM
08XRedRockHD's Avatar
Crate Axles
Part # P5153825AF
Crate Axles
Part # P5155359
Or you could replace it with stronger unit like DynaTrac PR44, TeraFlex Tera44 or Tera30 so you dont have to worry making the tube & c stronger to resist bending.
Quick Reply: Can I put this Dana 44 on my "X"
