cat removal options ,02 sensor 2 code removal
Old Apr 7, 2009 | 03:58 PM
RedneckJeep's Avatar
Originally Posted by mEthOdsOMahAn
in theory !
No, in reality. People use them all the time.
Old Apr 7, 2009 | 04:00 PM
john smack's Avatar
Well a little easier option would be an O2 trick box I bought them for my 97 Chev when I took out the cats..... You unclip the O2 sensor from the wiring harness(There was a connector on my truck) and plug this little black box into instead of the O2 and it would sent the appropriate signals to the computer. These worked great for me and I never had a code or check engine light again. I do not remember what they are called but I got them from a performance shop and they were around 80 Canadian Cedar Chips per unit. so I think in total it was a little under 200 bucks. I will see if I can find out what or who makes them and such details.
Old Apr 7, 2009 | 04:03 PM
john smack's Avatar
Redneck knows what I am talking about
Old Apr 7, 2009 | 04:20 PM
nangulator's Avatar
Originally Posted by d0wnShifT
There were ways to defeat the O2 sensor CEL in my Volkswagen GTI that other people were doing that I fortunately didn't have to do because of my aftermarket programming. What they did was get spark arrestors and thread them into where the rear o2 sensor goes on the header... then put the sensor on the end of it. Logic for this was that it still would heat the sensor, but put it far enough back in the exhaust stream to keep it from getting a CEL. Results were mixed with this solution. Here's a pic of the arrestors and 2 links for more information...
http://forums.vwvortex.com/zerothread?id=3850970
http://forums.vwvortex.com/zerothread?id=2363498
this works great on the O2 sensors after the cat, I have never tried it on the upstream ones
Old Apr 7, 2009 | 04:23 PM
mEthOdsOMahAn's Avatar
upstream sensors do not require this due to the cats do not effect sensor 1
Old Apr 7, 2009 | 06:22 PM
nangulator's Avatar
It all depends on the vehicle that you are working on, alot of the German car (05 and up) upstream sensors actually do look at the downstream sensors
Old Apr 7, 2009 | 07:11 PM
d0wnShifT's Avatar
I know with my old car, an 04, the front sensor is for the AFR and rear is cat efficency. One doesn't care about the other.
Old Apr 7, 2009 | 07:37 PM
officer_vince's Avatar
Is it worth the performance/mileage gains to eliminate the cats in the JK?
Old Apr 8, 2009 | 02:51 AM
JC JK's Avatar
Is it worth the performance/mileage gains to eliminate the cats in the JK? I would say not enough ot cut up a good Y-Pipe with cats. I was looking in to this but to hollow them out and put it all back looking stock was not worth the Time or money. God luck on your 02 Eliminator.
Old Apr 8, 2009 | 03:26 AM
Probably not, but tellin some folks that is like talking to a damn rock.
