cat removal options ,02 sensor 2 code removal
Well a little easier option would be an O2 trick box I bought them for my 97 Chev when I took out the cats..... You unclip the O2 sensor from the wiring harness(There was a connector on my truck) and plug this little black box into instead of the O2 and it would sent the appropriate signals to the computer. These worked great for me and I never had a code or check engine light again. I do not remember what they are called but I got them from a performance shop and they were around 80 Canadian Cedar Chips per unit. so I think in total it was a little under 200 bucks. I will see if I can find out what or who makes them and such details.
There were ways to defeat the O2 sensor CEL in my Volkswagen GTI that other people were doing that I fortunately didn't have to do because of my aftermarket programming. What they did was get spark arrestors and thread them into where the rear o2 sensor goes on the header... then put the sensor on the end of it. Logic for this was that it still would heat the sensor, but put it far enough back in the exhaust stream to keep it from getting a CEL. Results were mixed with this solution. Here's a pic of the arrestors and 2 links for more information...
http://forums.vwvortex.com/zerothread?id=3850970
http://forums.vwvortex.com/zerothread?id=2363498
Is it worth the performance/mileage gains to eliminate the cats in the JK? I would say not enough ot cut up a good Y-Pipe with cats. I was looking in to this but to hollow them out and put it all back looking stock was not worth the Time or money. God luck on your 02 Eliminator.
