CB Mount
Old Jan 27, 2015 | 01:30 PM
Jeepnut67's Avatar
Post Rugged Ridge makes one as well.....
similar to the SFZ one above. That's what I'm using for my Cobra 19
Old Jan 27, 2015 | 04:33 PM
Cutman's Avatar
That's really sweet but I must not understand correctly. Does that come with a GPS/CB/Radar detector as well? It's listed at $1,249. I'm clearly missing something.
Old Jan 27, 2015 | 04:56 PM
MotoJeeper's Avatar
Veteran: Marine Corp
That almost got me too. If you scroll down it's $25. It's 1200 for their half doors.
Old Jan 27, 2015 | 05:00 PM
Sturgeon12's Avatar
That was the price for their doors (4)... scroll down in that paypal oder box, the bracket is listed for $25 i think. Kind of a confusing way to place an order for sure.
Old Jan 27, 2015 | 05:10 PM
big dr's Avatar
I like the custom overhead setup detailed in the first response,, the one with the shelf standards!! Seems like a cheap way to get it done.
I have a similar suggestion. I recently installed a Rock Hard sport cage, and found a suggestion to use a KC Highlights light mount for a way to mount the CB to the center of the upper cross bar. I think you could call Rock Hard and just purchase the single upper crossbar, mount it to your stock cage (which it does anyway and is supper easy),, then use the KC clamp to mount your CB to the front crossbar. Although I like what was posted earlier,, I think this would look much cleaner and add to the rigidity of the stock cage. Although it will definitely be more expensive. You might be able to get Rock Hard to sell you that upper cross bar for $100. The wiring was extremely easy. I ran the power wires behind the windshield and a pillar plastics to the drivers side and ran the antenna the same way down the passenger side.
As far as I know, this has never been done before, which doubles its cool factor!!!!
KC HiLiTES Universal Light Mount Tube Clamp Bracket
ID:	593999   Click image for larger version
ID:	594000   Click image for larger version
Old Jan 29, 2015 | 03:56 PM
erpeden's Avatar
I bought the Rugged Ridge cb mount and really like it.
Old Jan 29, 2015 | 07:07 PM
big dr's Avatar
ignore everything i said above!!!!! this mount seems to do the job for a fraction of the price!
Old Jan 29, 2015 | 08:01 PM
slingshot289's Avatar
I made mine for about 50 bucks plus like 10 for powder coat
Old Jan 30, 2015 | 06:59 AM
MAG00's Avatar
Can you provide some more pics and info on you overhead system?
Old Jan 30, 2015 | 08:24 AM
auceny's Avatar
Does it get in the way when putting the tops on or off?
