Clearance Question
Old May 10, 2009 | 02:04 AM
zoomzoomjr's Avatar
Since I just got out of work, I thought it was in reference to a SALE when I first saw this...
Originally Posted by misha
If I understand the mechanics correctly the only thing that affects ground clearance is the tire size. The lowest point on the Jeep's bottom will be the differentials and shocks-arms attachment points, of witch the differential is probably more important. When you increase the tire size you lift the differential by 1/2 of the tire diameter increase. I have 29" tires and going to 33" - it gives me 4" difference - or extra 2" of ground clearance. The lift kit lifts the body by the stated amount - increasing you body height in addition to the "tire lift" so when I get 2.5" lift the bottom of my body will be higher by 2.5" given by the lift kit + 2" from the tires by a grand total of 5.5" but those 5.5" are mostly helping when straddling obstacles like rocks and logs, my pure ground clearance is still only 2" bigger than before. I leave out the discussion about effect of the suspension/body lifts on the articulation and vehicle's ability to clear much bigger obstacles - ground clearance is still the ability to "clear" or ride over obstacles between the wheels on flat surface.
P.S. Guys I am not trying to start a flame war here
Originally Posted by nthinuf
Are we talking about ground clearance? I thought he was asking about tire clearance in the wheel well. My bad...
Hmm... you know what... maybe you are right, and I am ranting about the wrong subject... Oh well...
If you are talking pure ground clearance, 32" vs 33" will give you about 1/2" difference, and that depends on the tires...
If those are the true sizes, then 1/2 otherwise, a 32.2 can be a 32, and 32.8 can be 33, so you'd only get .3" in that case!
If you are talking about another type of clearance, I have no idea right now, as I am tired from work...
