Coilover Questions..
Old Jan 24, 2013 | 03:53 PM
ttechris's Avatar
Long arms won't get you any more travel.
I am running 12" coilovers now, and the only thing limiting my downtravel is the shock length. I have a set of 14" coilovers going in this weekend, and even with those the only thing that will limit my down travel is the draglink I am currently running(Hits my sway bar link.)
Old Jan 24, 2013 | 04:08 PM
JKingAround's Avatar
You get a steeper angle on mid arms compared to a long arm witch in total will cause a bind or a limit in downward travel. Then if your talking the bushing in stock arms forget about it. That's why with a jk you can't go bigger than a 4.5 with a mid arm.
Old Jan 24, 2013 | 04:14 PM
And I got my info from Chris at Evo because I was thinking of going that route and didn't want to drop 7 G's so I went with a mid arm first. I figured I'd change it out later and sell my mid arm.
Old Jan 24, 2013 | 04:19 PM
PGH08JK's Avatar
I do have Adjustable Rock Krawler Upper and Lower Control arms if that makes any difference I'm not to good with suspension
Old Jan 24, 2013 | 04:23 PM
ttechris's Avatar
I have 100% usable down travel with my metal cloak arms and 12" Radflo coilovers. Disconnecting the shocks nets me another few inches before anything else binds(Confirmed this when I pulled my axles to do some work on them.)
All this is from my first hand experience, everyone setups may vary.
Old Jan 24, 2013 | 04:54 PM
1995nscajeep's Avatar
Not meaning to hi jack but what's the advantage of coil overs
Old Jan 24, 2013 | 04:57 PM
Atch's Avatar
There's a guy in our club that has STOCK arms with enough lift to run 42's not sure on exact height but its over 4.5
Old Jan 24, 2013 | 04:59 PM
Now tell me how you get as much travel as an Evo with Kings. No wonder you bottom out and don't bind. Your radflow a don't get a true 12" of travel.
Old Jan 24, 2013 | 05:07 PM
And his caster is horrible and his jeep rides like sh-t on the road plus his pinion angle on his drive shafts. And prone to Death wobble. I never said you can't do it. You can put lipstick on a pig but it still don't make her a beauty queen.
Old Jan 24, 2013 | 05:12 PM
ttechris's Avatar
12" of shock travel is 12" of shock travel no matter the brand.
