crazy noise help
Old Feb 26, 2010 | 01:24 PM
scbesse's Avatar
Default crazy noise help
Just got in from driving jeep and the drivers rear tire is making a nasty clunking noise when i let off the accelerator, not touching breaks, just letting off. It still makes the noise when breaking???? but not when i accelerate. any ideas?
Old Feb 26, 2010 | 01:25 PM
JK-Tex's Avatar
Have you removed the wheel recently? If so, double check your lug nuts. If one is loose, it can make this noise on deceleration.
Old Feb 26, 2010 | 01:34 PM
scbesse's Avatar
. EDIT was wheel lugs and I havnt removed wheels in like 3 weeks
Does this under deceleration straight, turning,
I walked along side of jeep while wife drove sounds like coming from in the wheel dont think its ice, started half way home on wet roads
Old Feb 26, 2010 | 01:41 PM
scbesse's Avatar
It was all 5 lugs that were loose! OMG did someone loosen these on pupose???
Old Feb 26, 2010 | 01:44 PM
Ko-hai's Avatar
Its not very common, but here is what I found working for Goodyear one day.
A woman ran over a small piece of piping/metal. It went in to the tire, but the tire leak was so slow that even a dunk test barely showed anything. After taking the tire off, we found the culprit. it rolled against the tire under centrifugal force. Once the wheel slowed so did the force and the object rolled around between the tire and rim like a quarter in a dryer.
Old Feb 26, 2010 | 01:46 PM
scbesse's Avatar
Originally Posted by toad
OK..that's scary.
Tell me about it. I have had to wheel studs break off on the same wheel. Now this.....how is it possible that all 5 were loose? Havnt has the tires off since I did the the lift and I tightened them, all other lugs are fine
Ko-hai's Avatar
Always make sure you double check your lugnuts after driving. They should have the proper torque applied. Get yourself a torque stick if you need to. then after a few short driving tips, recheck them. I doubt anyone would loosen them on purpose.
Tampering with a motor vehicle is a crime. Call McGruff if you find a culprit
Old Feb 26, 2010 | 01:49 PM
scbesse's Avatar
haha they were torqued. just cant believe only the one tire. Normally i would feel vibration wile turning if some were loose went thru that before
Old Feb 26, 2010 | 01:58 PM
Ko-hai's Avatar
That is weird. Good thing it didn't come off completely for your safety. Also remember to try lock-tight solutions. A little on each stud can ensure you don't have a mishap like that again. Inexpensive product to prevent an expensive disaster
Old Feb 26, 2010 | 02:23 PM
scbesse's Avatar
Was just saying that. i have red and blue sitting in the garage. might put a dab of blue on them.
