Currie Lower Control Arms:
I'm going to install my new OME lift tomorrow... I purchased it with currie lower control arms. Was there supposed to be hardware included??? Or does it use the factory bolts????
Hmmm... The only reason I'm wondering, is because WOL drilled out the upper control arm mounting brackets for 1/2" bolts... And once I start this project, i'll be stuck in my driveway, with no way of getting the extra parts!
That was on the uppers , I don't know about drilling for the lowers. If I were you, I'd call Currie tomorrow and see what they say. Or just undo 1 control arm bolt and see how it fits in the Currie arm. If the hole is a good bit bigger than your stock bolt, you'll need a bigger bolt, hence drilling the brackets. Or you could just PM WOL tonight.
Upon looking into it further, I think he only drilled one.... I'm not EXACTLY sure why, but I guess he had to cut the bolt to get the factory bolt out???
Hopefully I wont need to do any drilling tomorrow...
