Originally Posted by jtphoto JK
(Post 4267504)
Truss, C gussets, and heavy diff cover to support the center section.
Originally Posted by lucky5
(Post 4267561)
Anyways, back on topic, as far as ease of installation which brand would be the best truss kit? Who do you prefer? Been looking at the EVO, Blue Torch and Artec kit. I like the EVO kit because I won't have to weld to the chunk and since it essentially will become one piece once finished.
Found two of them: https://www.jk-forum.com/forums/modi...-truss-330764/ Starting around post #77 in this one. https://www.jk-forum.com/forums/modi...-338618/page2/ |
Originally Posted by nthinuf
(Post 4267567)
Some folks on here don't really have a high opinion for the trusses designed for 'JK' axles, but there have been a couple threads in just the last few weeks talking about it.
Found two of them: https://www.jk-forum.com/forums/modi...-truss-330764/ Starting around post #77 in this one. https://www.jk-forum.com/forums/modi...-338618/page2/ Hindsight being 20/20: The check would have gotten you most of the way to a Teraflex D30. The resale value of even a beefed up D30 won't be as much as what the insurance company paid for it bare. |
You say you are budget strapped, don't waste a dime on a dana 30. From bending inner C's to broken tubes the axle is not as weak as it is made out to be on the forums. Over a million JK's sold and I have only seen maybe a dozen broken axles or ones with bend C's. That a pretty good failure rate for any product. If you don't have the funds to upgrade then don't abuse your jeep, just common sense. If the axle was as bad as people make it out to be there would be several lawsuits and a recall on the front axle. Put the money you would waste on upgrades into a emergency account and keep saving and recovering from the divorce.
Best answer so far and I TOTALLY AGREE^^^^^.
Originally Posted by TheDirtman
(Post 4267691)
Coming from someone that currently has a dirty-30, I couldn't agree more. I've got c's, pound in sleeves, teraflex ball joints, and a rancho front skid. As much as I need a regear, I'm not spending another dime on this D30 but it will get through most as long as your not hard throttling the gas and axle-hopping your front axle. |
(Post 4267691)
If you have been wheeling with 37's for a while now. You have probably already bent the tubes and Cs
I've not had a single problem until I hit a culvert at 30mph. Haven't seen the first indication that anything is out of line or bent. I've had 37's on it for over a year now. Guess it's about how you drive and treat your stuff. This thread has turned into "you need this axle because", instead of the select few that actually mentioned anything about actually trussing or adding gussets on my d30.
(Post 4267872)
You don't NEED to truss or strengthen at all for what you plan on doing, but I would still suggest the heavy diff cover to protect the gears.. Not sure if it was mentioned already but you do need a 3-4" lift to accommodate a truss.. |
