Dana ultimate 60s show and tell
Old 10-24-2016, 03:37 PM
Jasoncinpean's Avatar
Default Dana ultimate 60s show and tell
Guys who run these axles please show and tell me about your axles. How do you guys like them how long have you run them and negatives etc. thanks!
Old 10-25-2016, 05:08 PM
koasta11's Avatar
I have about 30k on mine I like them a lot I haven't had one problem with them I have beat them in the desert with no issues at all. I paid 14,400 for them delivered to my door. Actually the only problem I have had is the brakes are so big I couldn't balance them with weights they would hit my Wheel so I now use balancing beads which I love.
ID:	659673   Click image for larger version
ID:	659674   Click image for larger version
Old 10-26-2016, 01:18 AM
Biginboca's Avatar
Koasta, what wheels and size are you running that barely fit over the brakes?
Old 10-26-2016, 05:30 AM
Extremneon's Avatar
I have them... zero problems to report.
Old 10-26-2016, 08:19 AM
Wightmn's Avatar
I have 8 months and 9k miles on them with a Hemi pushing. Great axle.
Only thing to watch is your your front wheels for play. My unit bearing nuts were loose. Torqued them down and are good to go.
ID:	659710   Click image for larger version
Old 10-26-2016, 08:44 AM
Originally Posted by Wightmn
I have 8 months and 9k miles on them with a Hemi pushing. Great axle. Only thing to watch is your your front wheels for play. My unit bearing nuts were loose. Torqued them down and are good to go.
great awesome man! I just ordered a set should be getting them by the end of the week fingers crossed
Old 10-26-2016, 10:07 AM
Former Vendor
RiverCityOffroad's Avatar
I have them in mine and am very, very happy with them.
Here is my build thread: https://www.jk-forum.com/forums/jk-g...-build-293351/
We have awesome pricing on these axles and we know them inside and out, top to bottom.
http://www.rivercityoffroad.com/Ulti...-p/ud60pkg.htm
Marcus
Old 10-26-2016, 01:38 PM
Former Vendor
TOTL Innovations's Avatar
We have had the same experience on ours. These actually dont unit bearings. Its the jam nut on the spindle that is the issue.
Also if you upgrade from the Warn hubs to Yukon, you may have an issue with the clicking style lock nut these come with and will have to change over to traditional nut.
Old 10-27-2016, 09:30 AM
John_fender's Avatar
Installed these this spring and now have 20K miles on them without any issues. Have the 4.88 running
37 inch toyo r/t tires on trailready wheels. I use my jeep as an expedition more than a rock crawler.
Last week when on a trail with a 10,000 ft summit I really loved having the huge brakes on the descent.Click image for larger version
Old 10-28-2016, 02:21 PM
Originally Posted by TOTL Innovations
We have had the same experience on ours. These actually dont unit bearings. Its the jam nut on the spindle that is the issue. Also if you upgrade from the Warn hubs to Yukon, you may have an issue with the clicking style lock nut these come with and will have to change over to traditional nut.
can you guys be more descriptive on the issue you are both bringing up? I'm use to dana 44s and dana 30s nothing with a huge locking hub and such thanks!
Quick Reply: Dana ultimate 60s show and tell
