death wobbel with tire switch?
Old Dec 3, 2013 | 06:06 PM
  #41
planman's Avatar
Forum Tech Advisor
Originally Posted by fultonromero12
Did everyone overlook the fact that he said drivers side tire sticks out further than the other side? If that's the case the axle is not centered correctly. That would cause a hell of a death wobble
An off center axle would not cause this:
http://www.youtube.com/watch?v=vwiv23dLhMY&feature=player_embedded
Old Dec 4, 2013 | 04:12 AM
  #42
drexelsteve's Avatar
A "little bit" of play in your balljoints can translate into a lot of death wobble. There shouldn't be any play in them. Worn motor mounts can also cause death wobble, but track bar is usually the first suspect.
Old Dec 4, 2013 | 04:17 AM
  #43
rt chips's Avatar
Do you guys know if when installing the synergy tre in the stock location and after drilling out, do i have to place the metal drag link adaptor, or is that just for the flip?
Old Dec 4, 2013 | 05:04 AM
  #44
planman's Avatar
Forum Tech Advisor
You don't drill it out to run in the stock location. That is only for a flip to reverse the taper of the hole.
Old Dec 4, 2013 | 06:00 AM
  #45
rt chips's Avatar
Okay thanks
Old Dec 4, 2013 | 06:46 AM
  #46
Cajun JK's Avatar
I would still replace the ball joints. If they are going out won't they cause the track bar the act up. I was told that ball joints are the main issue with D/W.
Old Dec 4, 2013 | 08:07 AM
  #47
rt chips's Avatar
Thanks. My local 4 wheel shops sells synergy. I have a set arriving from them on Friday. Although they don't install them there I found a shop that would for around 400. I don't think that I can handle this job by myself.
Old Dec 4, 2013 | 08:35 AM
  #48
planman's Avatar
Forum Tech Advisor
It is a 3-5 hour job, depending on your experience, and should include an alignment.
Old Dec 4, 2013 | 08:47 AM
  #49
rt chips's Avatar
Thanks planman, while I have your responding, when I did the coil lift im not sure if I loosened the rear control arms! Should I do that?
Old Dec 4, 2013 | 08:51 AM
  #50
rt chips's Avatar
Also, I still have the steering stabilizer off. Should I drive it around with it off to feel the diyor anything
