Death Wobble...i know i know
Old Apr 16, 2012 | 10:37 AM
  #21
drivingfool's Avatar
I know a good jeep tech out in Bay Shore if you need some help, and OK4WD out in NJ is pretty legit as well.
Old Apr 16, 2012 | 10:46 AM
  #22
kashlak's Avatar
I was dealing with DW for about a year off and on. Even though I took it to a shop and everything was said to be okay. Last month I took it to another place to get checked out. I ended up needing ball joints and tire rod ends. I am running a 3 inch lift and have 62K on my jeep. I am not sure if your ball joints are the problem but I would have them checked out. I wish you luck trying to figure out the problem.
Old Apr 16, 2012 | 11:05 AM
  #23
chknkatsu's Avatar
I just had my prorock installed a few thousand ago with prosteers. I'll check it out even though i doubt that is the problem. If it is, then somebody will be getting an ear full from me
Old Apr 16, 2012 | 11:06 AM
  #24
chknkatsu's Avatar
Are you refering to evan? If so, i already called him yesterday asking him about my issue
Old Apr 18, 2012 | 03:16 PM
  #25
chknkatsu's Avatar
Originally Posted by planman
Post #2 is the inspection checklist:
i've read your diagnosis thread several times already
i even went to your youtube channel to look for more deathwobble related videos
Old Apr 18, 2012 | 03:34 PM
  #26
F200's Avatar
I think the track bar in the video has to much play. If you have that much play I would take it apart and see if it is bolts, holes, or bushings.
Old Apr 18, 2012 | 03:47 PM
  #27
Runewolf1973's Avatar
It kinda looks that way to me as well.
Old Apr 18, 2012 | 05:11 PM
  #28
chknkatsu's Avatar
im going to try to get a clip of my trackbar and post it up
Old Apr 19, 2012 | 04:07 PM
  #29
chknkatsu's Avatar
another update
so today, once again i went on a search for the cause of my deathwobble. i rotated my tires, checked every bolt AGAIN and have each bolt a good hit with my impact gun. everything looked good except for my drivers side upper arm frame side mount which i got a couple of turns out of. but besides that, everything looks top notch. ball joints are good. the only thing that is questionable is my pitman arm joint on the knuckle, it pops up and down a little when turning the wheel left and right and my very slight trackbar bushing flex
Old Apr 19, 2012 | 06:26 PM
  #30
chknkatsu's Avatar
http://www.youtube.com/watch?v=lFExM9hyAnk&feature=youtu.be this is my trackbar video. this is with the steering wheel turning from 10-2. bolts have been replaced already
